Many Basic Questions
Bob S
>Here's what I need: MORE INFO,MORE INFO, MORE INFO. One more day playing on the lathe in the workshop and I am now thinking this is more difficult than I thought.
1. I am trying to make table legs (spindles?). The pattern shows they are 1-7/8" square blocks (in the un-turned top and bottom portions). There are beads that are about 1-7/8" on the leg. Question: Should i start witha 1-7/8" square blank, or should I start larger, and trim square portions on table saw. I am very unsure of the order to proceed with this leg.
2. I have a copier attachment. Is it worth trying to make the template and use it to make 4 identical legs, so far I have spent a fair amount of time making the template and still am not happy with it. Opinions on this would be appreciated.
3. How am i going to make the little bevel that transitions the square block protions of leg. (sorry i don't know the names of these parts). The square block, has a small portion of each corner rounded down just a bit. Eac time I try this, I get a rip. What tool should I be using, and what speed?
4. Is there anyway to tell if the blank is perfectly mounted?
5. Is it okay to take the leg on and off the lathe, or should it be mounted and turned until completion.
Thanks, and thanks for patience!
Bob
Re: Many Basic Questions
Here's how... *LINK*
This is an article by my dear departed pal Steve Blenk that appeared in American Woodworker #59 (June 1997). It answers all of your questions.
Cheers,
Ellis Walentine, Host
STeve Blenk: Turning Table Legs
Re: Here's how...
Bob S
Awesome article, thanks. Now if i could only print it out.
My take
1. I usually start a little bit oversized and use a hand plane to plane it square. Usually when you line a blank up on a lathe, it never is "Exactly" in the center. If you have just a bit oversized, you can finish squaring it up.
2. I don't have a copier attachment. I make my legs by eye along with the rest. You can do reasonably well without.
3. I usually use a skew. Sometimes I use a spindle gouge.
4. I usually line up the blank as best I can. I then mount it and turn on the lathe. You can usually see if the edges are spinning in the correct orientation.
5. I often demount a leg. I am however thankful for the Sorby Steb centres - they make it easier to mount and demount. Usually, I turn a leg to completion. I figure once it is on the lathe, why bother taking it off.
