How should I treat my short logs
ted evans
>Hello everyone,
I have a question that surely has been answered before but I could use an answer quickly if someone would be so kind.
I have some maple, approximately 20� in diameter that I would like to cut into two pieces for bowls. My question is, how should the wood be treated being that I cannot get to them right away to rough them out? I am using Anchor Seal, should just the end grain be treated or should all places without bark also be treated? Should I store them on a trailer with a cover over it or would they be better in the basement?
Thanks for your suggestions.
Ted
Re: How should I treat my short logs
>Seal them with anchorseal on all endgrain portions. Get them out of the sun and wind, that speeds up the drying and caused cracks. If the basement isn't heated that's excellent. Leave them long so if there is any checking you can cut that out by cutting the ends off before cutting your bowl blanks.
End grain sealer isn't a cure all so try and get them roughed out as soon as you can. Getting them out of the weather and off the ground is just as important if not more so than end grain sealer.
ted evans
>Hello John,
Thanks for the information. The basement is not heated and is mostly dark so that might be a good place for it. I am not sure the wood is worth a lot of effort, it is, I think, soft maple, and I have not found a lot of character in it so far. I need the practice thought so it should be good for that.
There are many limbs that are from 3 to 8 inches in diameter, do folks use them for anything and if so, what?
Thanks.
Ted
adrien
>small vases, stemware, weedpots, natural edge bowls for the small stuff
GaryG in MD
>Ted,
Two things.
First, if you're going to bring them into your house, please make sure they're not full of bugs!
Second, more applications -- mushrooms (see the work of Eugen Schlaak), small boxes, small spheres, fruit (pears, apples), holiday ornaments (bodies, finials, and icicles), pens, ladies scarf and hair pins, magic wands (Harry Potter style), honey dippers, dibbles, the list is as long as your imagination. For some of these items you may want to exclude the pith.
...Gary
