miniture turnings
Guy Bratt
>I was inspired buy John Lucas's miniture turnings last January.
I've made a few myself. I would like to see more and also some of the tools used to make them.
I also found a site that sells the large coins.
miniture turnings
Guy Bratt
Re: miniture turnings
Dennis Daudelin
>Miniatures are always fun. I do them a lot for demo's at open houses or club shows as they are fast to do and people love to see a finished project.
Here is a set of mini-goblets. The largest is 3" and the smallest is 3/4". I use normal mini-tools and did the captured ring with a modified dental-style tool purchased at Ace Hardware.
>I don't do many but I did these one day mostly to test a new macro lens for my digital Olympus. Fit on a penny.
If I remember correctly I didn't use any special tools, just a small skew and detail gouge.
>Guy for my doll house scale miniatures I use a 3/32 spindle gouge and a 3/8" homemade skew and 1/6" parting tool. I usually rough out with a 3/8" miniature roughing gouge that I got from Harbour Freight.
for my really small miniatures I have custom made tools that I made from .025" and .015" piano wire. The wire is held in 1/4" aluminum handles. I also have a custom tool rest for these. It steps down from 1" tool post and holds a tool rest that is 1/4" tall, 1/2" long and 1/8" wide. It's actually a short piece left over from my hanging file cabinet supports.
Keith Tompkins
Here's an ebony pen blank turned into a lidded goblet, the base 1 1/2" tall overall. I used conventional tools plus a 1/16" homemade coving tool. Notice captured ring on finial. Sorry for bad photo.
Mike Stafford
>Spraying a manhole cover with copper paint and stacking some turnings on it doesn't fool me....
Nice work John. The small scale work is fabulous and so is the macro photography.
Galen Vetterick
>I can just picture you guys down on your hands and knees trying to pick out the larger wood chips to make into your next miniture turning.
Wonder what you can turn from a toothpick or wooden match?
Is the microdust hard on your lungs?
Galen
adrien
>Keith, I took that photo and shrank (is there such a word?) it down to 11/2 inches. I need new glasses! Did you do that with a magnifier? Incredible.
Bob Macgregor
>The lid is a good idea; it will keep flies (well, gnats, anyway)out of the wine.
BOB
bob davis
>here is a mini within a mini.largest is appx 5/16 x 1/2
bob davis
Michael Mocho
>Here is the result of a bad case of the "minis" that struck me a few years ago. boxwood on the left, fossil ivory on the right- turned with a dental pick and a sewing needle ground and honed to shape
Better to take one's compulsive behaviors into the workshop where it won't hurt others ......
Galen Vetterick
>Those have to make a bottle of wine last a looooong time!
Even a single drop from an eye dropper is going to fill the one to overflowing.
Galen
Keith Tompkins
>Hi Adrien, No magnifier, but I have resorted to wearing 2.5x reading glasses for close-up work. I only started turning mini's when a demo with my friend Steve Sherman turned into a contest who could turn the smallest goblet. Part of the problem with the photo is I enlarged it, and the pixels show. Thanks
Guy Bratt
>Thanks. You folks are fantastic. When I started thinking mini turning, Micro turning this small never entered my mind. I've got some practice to do.
Michael... that goblet on Lincolns nose, is that an offset turning?
If you can may I see some of these specialized tools?
Michael Mocho
>Hi Guy,
No, it isn't offset (multi-axis), that's a free ring around the goblet stems. The smallest measures about 1/16" diameter and a bit over 1/8" tall- it kept falling over when I tried to photograph it so I left it on its side.
I don't have a photo of the mini tools, but they are essentially round-nose scrapers, used at a 45 degree shearing cut- about 1mm diameter. Honed with a hard Arkansas stone.
No cure for this condition, only treatment.
-Michael
www.mmocho.com
this is one of my smaller goblets. I have one about 1/4 this size out of cherry. With my new .015" tools I hope to make the goblet actually look more like a longer stem goblet. That's a pin on the right.
Did you start finishing this one with 80 grit?
Rob Wallace
Re: Did you start finishing this one with 80 grit?
>Rob I glued 1 80 grit particle to the end of my micro miniature boring bar.
