REAL MILK PAINT
Leg Profile *LINK*
Leg Profile *LINK*
Leg Profile *LINK*
Bob S
>Hi, Does anyone know a site or have an article that shows traditional TableLeg profiles? I am making a table with 'William and Mary' 28" long turned legs. The detail drawing i have is very poor resolution. See attached link. I am new to the whole 'turning' experience and could use additional guidance.
Table Legs
Re: Leg Profile *LINK*
Re: Leg Profile
>I can tell you what I do.
I've a couple of different types of graph paper. One sort is the standard 8 1/2 x 11, another is the 11 x 17 and finally I have some 24 x 36.
I usually sketch the leg on the 11 x 17. I use a french curve and refine the leg so that a) I'm happy with the curves and b) I feel that I can actually turn them! I then transfer the pattern to a piece of 24 x 36 graph paper. I cut out the pattern and glue it to a piece of 1/4" plywood.
For your particular legs, this should work reasonably well.
Some caveats.
Find the end centers as best you can. You will NOT be in the exact center, no matter how hard you try (DAMHIKT).
Use a hand plane to dress and square the sides when you are finished turning.
Make a few more legs than you think you need - consider making one or two practice legs first.
Remember - it is only wood. It grows on trees. If you rush - you will mess up.
My $0.02.
