Chainsaws and Horses
charlie belden
>I lived on a place that boarded horses. And it used to amaze me that girls who owned horses would spend a half an hour or more getting the horse and their tack set up for riding. And after an hour - at the most - of riding - they'd spend an hour washing down their horse and grooming him/her/it and another half an hour saddle soaping their saddles - and maybe riding boots. An hour on the horse - and three hours around horses - doing horse related things.
Chainsaws are sort of like owning a horse. You gotta get fresh gas - and mix in the oil, maybe check and clean the plug, maybe wire brush off any gunk you missed after the last time you used it. And while using the chainsaw, you often have to stop and clear out the wet gunk that should be automatically ejected - but because the wood is green - merely packs itself around the sprocket. An hour into cutting you're either done - or done for - and you stop. THEN you spend an hour cleaning it up - take the chain off and WD40 it, maybe wire brush the big gunk off it, clean the groove in the bare and the sprocket at its end, tooth brush sawdust and crud that you couldn't blow off with compressed air (did I mention that owning - and using a chainsaw benefits by also owing a compressor?) The you drain any left over gas, maybe pull the plug and put a drop of oil or two in the cylinder, pull the starter cord a few tiimes and then put the saw back in its case - checking that you have oil for the gas for the next use.
Like owning and riding a horse, two times as much time is spent preparing to use it and cleaning it aftterwards - than the time spent using it. And that's if you don't grab a file and spend any time sharpening.
Then I think about turning - and the ratio of "fixin' to"plus cleanup and sharpening to the actual turning time ratio is similards.
Odd this turning thing - but fun.
Re: Chainsaws and Horses
Sad, but true...
Jerry Hall
>and well put. But why did you have to point out this reality? Maybe this is why my shop is always a mess, and I pray each time for my dirty, abused, Echo chain saw to start after sitting for a month under a tarp in the rain and snow on the wood pile with old gas. God bless it, it always seems to start, at least by the ninth pull. This is why I host a chapter meeting once a year. Once a year things get cleaned up and maintained, even if they don't really need it. But I am going to change one of these days.....
Mike Peace
Mike Peace
>I see some of the "inactive hobbyists" that come to the chapter meetings but never seem to bring in anything to Show and Tell. I guess they have a Very High ratio of "Fixin' to" to turning.
Katherine Kowalski
Katherine Kowalski
>Interesting observation -- and I've seen it happen with many more activities than horses and chainsaws... (like model-building, etc.)
However, I MUST strongly disagree with the comment about turning -- I spend much longer turning than anything else... sharpening takes literally seconds (platform method is QUICK!), and cleanup is super easy.
Katherine
David Churnega
>As to chainsaws.
I purchased a buck saw a while ago and have found it amazingly fast but labor intensive. But then I have gained heart healthyness in the aerobics associated with repeated use. Getting better and losing weight in the winter.
Steve Kubien
Steve Kubien
>Perhaps I am lucky that I know so little about caring for a chainsaw, or anything with a gas engine. I don't tend to empty the gas as I think I use it often enough that it is not a big concern. There's a spark plug in there somewhere? Why? Why would I want a spark around something that runs on gas? Ok, I occasionally brush off all the exterior grud build-up but that it so none of it ends up in the gas tank or oil resevoir (sp).
Owning and operating something like a chainsaw includes the cost of taking it in occasionally for a tune-up. It is a cost I assumed with ownership and since I hate the internal combustion engine so much, and understand it so little about it. But that's just me.
Steve
-who doesn't understand people's obsession with horses either
>Although I agree with you somewhat. Turning is about the whole process. We should enjoy each part from prep to cleanup. It's a Zen sort of thing.
That being said I used my last chainsaw for many years with out ever really messing with it. Sure once in while when ripping I would have to stop and clear the sprocket. Sharpening takes about 10 minutes by hand and I do it usually only when I feel I really need it. Other than that I don't do much maintenance. I use a Husquvarna and it just runs and runs.
Now if you count thinking about turning and planning projects, that's when I get off into the zone. The reason is simple. This time of year it's just too cold and costs too much to heat the shop. Consequently I do little things all week waiting for the weekend. Then I can run the heater all night and actually stand to work in the shop during the day. Now in the spring I get a lot of turning.
You're supposed to CLEAN the saw?!
adrien
Dick Hines
Re: You're supposed to CLEAN the saw?!
Dick Hines
>The only thing I do to my saw is keep full of oil and gas, you never know when you will find a downed tree, sharpen the chain after every use and blow the dirt and chips before I put it away.
Steven Antonucci
Who cleans their chainsaws?
Steven Antonucci
>My Stihl has served me very well for 6 or 7 years, and my regimen is as follows:
Sharpen it if it needs it.
Once in blue moon, use a tooth brush to get the gunk (sawdust/oil mix) out.
Every couple of years give it to the shop to "overhaul" (whatever that is).
starts within a couple of pulls, and cuts like a dream.
There are those "Horse folks" out there that treat their tools like heirlooms to be passed on in their will, and I'll never understand them. You guys know who you are- with your polished ways on you lathes, and your surgically clean shops. I'd like to sneak into your shop one day and turn a toothpick from a wet oak log. That would teach you!
S
Re: Who cleans their chainsaws?
>Steve I guess I'm a little bit that way. My shop isn't surgically clean but it drives me nuts to have dirty tools or lathe. My chainsaw may be the exception because it's kind of a dirty tool being used in a dirty environment. Still I do take a brush to it occasionally and wipe it down pretty good. It does have to live in my clean shop with the other clean tools.
Fred
>Like all engines, the better it is maintained, the longer and better it will operate.
Changing the filter and plug regularly will help reduce unnecessary heat build-up and performance.
Keeping the sprocket clean after each use will lessen corrossion and wear, thus help to increase loop shelf-life and performance.
Dressing the bar will help to reduce heat build up and improve performance and stress on engine. And of course, don't operate with a dull loop.
Consequence of no chainsaw maintenance is the same as with an automobile, and there's no AAA when you are in the field.
Denis Putland
Re: I must have the dumbest
Denis Putland
>chain saw in de world. It seems to know nudding about this.
Quot Charlie
"THEN you spend an hour cleaning it up - take the chain off and WD40 it, maybe wire brush the big gunk off it, clean the groove in the bare and the sprocket at its end, tooth brush sawdust and crud that you couldn't blow off with compressed air (did I mention that owning - and using a chainsaw benefits by also owing a compressor?) The you drain any left over gas, maybe pull the plug and put a drop of oil or two in the cylinder, pull the starter cord a few tiimes and then put the saw back in its case - checking that you have oil for the gas for the next use. "
It just sits dare in de shavings in de corner of me shop and when I need it it seems to gladly start up and do it,s thing. It does seem to want me to use me dremel to touch up it's teeth every ounce in a while though. I do take de chain off to put a new one when de old one is ground away. I can knot find a best before label on me gas can so I presume it is good until it is all gone????
I am a sure gonna delete dis thread before me chainsaw has a chance to read it doe.
Denis
Jorge Casta�eda
>Katherine,
clean up is easy in the scale of your work, some of us go great guns with big pieces and the mess is astronomical compared with yours, but still a little time compared to amount of time that goes into sanding.
I find that.....
Tom Collins
>as I progress in my woodturning journey I spend more time in preparation. More time is spent in examining a log so I can utilize the features in the wood to best advantage. I spend more time in sealing the ends to prevent loss from cracks and I spend more time examining and orienting the blank on the lathe so, once again, I can take advantage of the wood's features.
I don't really have to spend all this extra time in blank preparation but my satisfaction level is increased. Both with the turning process and the final product.
Maybe that is why horse people spend so much time in preparation. They get extra satisfaction from knowing their animals are looking and performing their best.
TomC
Me!
Jorge Casta�eda
>I mus 'fess I do it, needed or not, every time I give it a new chain :b
The only thing I do to my Husky is to keep it full of gas and oil. Here is so humid that a full tank is necessary not to have condensation.
And I use it to make the firewood for the house and to prep my turning blanks.
Tune up? all there is to it is replace the spark plug and the gas filter and use a solvent, I use gasoline and a brush to clean and blow air to get rid of the gunk.
9 years and never gone back to the dealer. That must be the "half life", the previous one lasted 18 years....
Katherine Kowalski
Katherine Kowalski
>Jorge,
While I primarily market my crochet hooks over the internet, I also create contemporary artwork -- bowls, hollow forms, etc. where the "mess" is significant. Before each project, I separate between toxic and non-toxic chips, throw the safe ones into the compost pile for the garden, and toss the rest out. Still a breeze.
And sanding? It isn't so bad... :D
Katherine
mike nelson
>I have 12yr old tiller bought used! It sits in the corner of our garden, rain or shine. Starts every spring, had to replace a little governor hose once. I don't worry about it being stolen, looks like it couldn't possibly run!
Barb Siddiqui
Gee, and I thought
Barb Siddiqui
>I was inefficient having to stop and take care of the saw several times a day! Maybe I'm just doing a better job than I thought I was. :| And I grew up with horses. That preparing/riding/brushing is just a love triangle!
bill crommett
>Is it a tool or a toy ? A tool is to use and a toy is to play with. Put your toys away in the condition you want to find them the next time you decide to play. Put your tools away in the condition that will be needed to use them next time.
mike nelson
>Well, Bill it has been twelve years and 2.95 for the vac hose, 175.00 original cost. I also have a 340 59' Farmall that you will never see in a parade! Maintenance and cleanliness are not necessarily related. I do admire those that are able to keep a clean shop and still turn out a beautiful piece. I would have to hire someone ;)
Re: Girls and horses are a symbiotic....
JamieDonaldson
>....social disease, very frequently found here in Kentucky. And that's a professional observation after more than 40+ yrs. in the business, including my wife as a study example!
>That's the truth. The boys are interested in looking at my horses, but the girls keep coming back over and over, to look, touch, groom, ride, feed, clean up - anything to be around the horses. My theory is it has something to do with pheromones.
charlie belden
>Boys hang around horse stables because girls hang around horse - and occassionally ride them.
Three girlfriends had horses 45 years back. Oldest son's first girlfriend had a horse. We commiserated on how crazy girls are about horses, while boys are crazy about HORSEPOWER! And at a certain age girls attention shift from horses to HORSEPOWER.
It's funny. A guy will work his tail off to earn the money to get the car, then get another job to pay for the insurance, gas and maintenance. Then they get the girlfriend - and then - never have any money for the car - or much of anything else - except that spent on the girlfriend. Tyring to get them to understand this is an exercise in futility Hormones trump reason every time.
Bob Macgregor
>And here I thought this thread was going to be about a scene from Animal House...
BOB
