Hollow Forms
Hollow Forms
Hollow Forms
Don at Central Illinois
>I finally got some shop time on Monday. I made a HF, aka Ellsworth. Following the DVD I got for Christmas. My problem is measuring the wall thickness. I do not have laser set up. Any helpful suggestion will be appreciated. Since the one I made is for my daughter, she doesn't care about wall thickness, she just likes the outward appearance. Thanks in advance for any help.
Re: Hollow Forms
Re: Hollow Forms
Randy Gleckler
>I'm probably going to fail at explaining this well, but I do fairly well with a setup I learned from Trent Bosch.
Basically take a metal rod/wire that's thick enough it holds it's form, but flexible enough you can somewhat easily bend it. At one end put a 90 Degree bend in it. Take the other end and wrap it around so that it's even with the end with the 90degree bent end... So basically you have a circle with a kink in it. The space between those ends you can use to measure the sides of the hollow form.... Use the portion with the kink in the end on the inside for the top 1/2 of the hollow form, and the other end inside for the bottom half... based on angles this gives you the best thickness gauge.
How it works... if you leave a 1/2" gap between the two ends and put it in the Hollow form to measure and see no gap... your probably still do thick. If you see 1/4" (ish) gap, you have a 1/4" ish thickness... if you see both ends... You probably are working on a bowl at this point. :-D
Hope that all makes sense.... and it's cheap as you can usually use the wire from those Election or temp Real estate signs sitting on the side of the road everywhere. :-D
Re: Hollow Forms
Steven Antonucci
Bent wire caliper
Steven Antonucci
>use a wire hanger with a c shaped bend in it. the gap in the c is closed to a known distance and you measure the wall thickness by taking the delta between the gap and the set distance.
That's David's caliper of choice...mine too
S
Re: Hollow Forms
Re: Bent wire caliper
Randy Gleckler
>Or.... I could have explained it Steve's way. :-)
Re: Hollow Forms
>I tried the coat hanger, but couldn't keep it at the right distance between points. There are enough election signs out, I may pick up one of those and use that wire. That is basically what Ellsworth uses, I just didn't have the right wire. Thanks all.
Re: Hollow Forms
Brad Vietje
Brad Vietje
>Don,
The shape of the caliper can (and probably should) be changed to work well with the different forms you are making. I keep needle-nose pliers right on my turning bench to bend and re-shape these wire calipers.
I use 10 ga. copper or aluminum wire for smaller forms -- you can usually get some 10-2 Romex at the hardware store, or even better, look at the bare copper grounding wire they usually (should!) have on spools for sale by the foot.
Safe spinning,
Brad Vietje
Newbury, VT
Re: Hollow Forms
Steven Antonucci
Armature wire
Steven Antonucci
>Sold at the hobby stores, used for making skeletons in clay figures. I have about 10 of them in sizes and shapes so that I am always close to having what I need.
S
Re: Hollow Forms
>One thing not mentioned it that you need to measure the wall perpendicular to the sides. You can bend the wire anyway you want. I usually leave a know gap of 1" so it makes easy to remember. then when I put it in the vessel I make sure my ruler and the bent wire is perpendicular to the side where I'm measuring. If you don't have it perpendicular than you will get an inaccurate reading because you will be reading at an angle.
Re: Hollow Forms
Dick Hines
Dick Hines
>I use the ones made by Veritas. They are not as cheap as wire but I have had good luck with them.
You just stick them in the hollow form turn the little wheel to adjust them for the thicknest of the form. Then open them and take them out and check.
Re: Hollow Forms
Steve Kubien
Re: Hollow Forms *LINK*
Steve Kubien
>Being cheap basically, I just bought to stufff to make this gauge from the Articles section, right here on Woodcentral. I haven't made it yet but it looks promising. See the link below...
DIY Faceplate Caliper
Re: Hollow Forms
Re: Hollow Forms
>I have several of the bent wire ones everyone has been discussing. Mine are made of copper "ground" wire. I find the copper just right to bend. Hard enough and tough enough to stay in position once you bend it, but soft enough that you can bend it fairly easily.
A couple of things no one has mentioned. Once you cut the wire to length smooth the ends. You may want them slightly rounded, but no sharp points or edges. If the ends are left sharp they will scratch the surface. DAMHIKT
And, practice your grip on the caliper. Your technique needs to allow you to move it around and control it, but not flex it. If you just give it a little squeeze, you and change the setting or spacing dramatically.
They get flimsy as they get larger, so make a set that is just big enough for the piece.
I set mine at about half an inch an use them as a go/no go gauge and then thin from there to what ever I want.
Re: Hollow Forms
Carole Valentine
>Ditto on the Veritas. It's a good caliper.
Re: Hollow Forms
Re: Hollow Forms
Wally Dickerman in Arizona
>The caliper shown in the article is an exact copy of one made and marketed by Dennis Stewart for years. That should have been mentioned in the article.
I have had the Stewart model for years and it is a very good one. It is especially good for measuring the thickness of the bottom of a bowl or vessel.
Wally
Re: Hollow Forms
Re: Hollow Forms
Don @ Central Illinois
>I remember that thread. But getting old and senile, I forgot all about it. I did stop by the roadside on the way home and confiscated a campaign sign (he won, so he won't care) and will try that first.
Re: Hollow Forms
Steve Kubien
I had no idea...
Steve Kubien
>Thanks for this Wally. Always good to give credit where it is due.
Steve
Re: Hollow Forms
Re: Hollow Forms
jim miles  - Charlote NC
>Another method - especially if you have rough surface etc that it won't show too much --- drill the smallest hole you can through the side of the wall in a couple places ---insert a wire - you can get an exact thickness- can fill hole when done
Re: Hollow Forms
Re: Hollow Forms
Carole Valentine
>Arrgh! There is something about intentionally drilling a hole in a turning just to check wall thickness that really goes against my grain, especially when there are so many other ways to do it accurately.
