>I am new to turning & have been practicing turning bottle stoppers. I buy the blanks as I do not have the equipment to make them myself. The blanks come with waxed ends & are not always flat. I turned a stopper yesterday & found it would not seat squarely on the metal stopper. How can I finish the bottom, so I can maintain a square edge to fit flat on the metal stopper.
1. Finish sand and square the bottom to the most perpendicular side first at a stationary belt or disk sander with a square flat rest to the sander. Then careful working thru the grits (to 320) with a sheet of sandpaper on a flat surface.
2. Drill your mounting hole, indexing on the chosen perpendicular side, with a right angle jig (L)at the drill press. use a spring clamp need be.
3. Make an 1/4" MDF washer for your mandral the diameter of the stopper end. Then you can clean up and shape the side of the end easily, into coves, beads, whatever without mucking up your spindle gouge.
4. Support with the tail stock with a non-invasive live center as long as you can.
5. If all else fails make it eccentric (see picture) and no one will notice!
Works for me! OMMV If the end is not to bad I may do all the sanding as above after the stopper is turned, but it is not as effective sometimes.
>Put your blank in your chuck, with the bottom towards the tailstock. square with your tool of choice. Personally, I think slightly undercut is even better. I also tap my hole to match the threads on the stopper.
Once you've done this, you cut the stopper backwards towards the headstock. If you buy a stopper mandrel (or make one), you can just thread the blank onto the mandrel and turn it normally.
I like to drill the hole on the lathe and turn the bottom first, as shown in this photo:
(It's nice to turn a tiny recess for the stopper to fit into for a more finished look.) With this particular pointed design, finish most while still connected, cut it loose while shaping the point, then finish the point by hand.
For other designs where you want free access to the top for shaping and finishing, you can still start on the base as above then part off, turn it around, and remount on a turned jam chuck made of wood, a pin chuck, or a mandrel such as this one Ruth Niles offers for sale - it has a morse taper and a threaded end for the stopper:
You can also simply chuck a piece of threaded bolt in a jacobs chuck and thread the stopper on the end. A pin chuck is easy to make and works great - all you need is a piece of steel rod, a file, and a small brad nail.
>I drill mine on the drill press. Then I glue in the dowel. I chuck it up holding he dowel in my chuck jaws leaving about 3/8" of dowel showing. then I bring up the tailstock. I true up the blank and then turn the bottom. Then I loosen the chuck and push the stopper bottom against the chuck. this reduces the vibration so I can turn the rest of the stopper.
If I didn't have a drill press I would chuck up the stoppers and drill them on the lathe.
>John K. and I approach the same way. I like to keep it simple too. The recess really gives a nice finished look. I also use Ruth's mandrel to finish off the top.
>I'm with John K, Barb and Steve. I probably only do about 20 stoppers per year unless a special order comes in so I used a 3/8" bolt epoxied into a chunk of wood which is held in my 4-jaw chuck.
