Re: O.T. Algorthym
Bill Turpin in WNC mountains
>Heat pumps transfer the heat contained in the outside winter air into the house. They start loosing ground at about 45�. Most systems have auxilliary electric heat strips that start coming on at 28�. The outside unit's freon is below freezing, so any humidity in the outside air freezes, which will eventually stop up the outside coil. When the coil ices defrost is required. During defrost, the unit reverses cycle and becomes an air conditioner. Auxilliary heat is required during this period. Is your propane furnace providing this or do you have strip heats also?
A BTU is the amount of heat necessary to raise the temperature of one pound of water one degree F. A kilowatt hour is 3413 BTU. A gal of propane = 91,500 BTU. A cubic foot of propane = 2570 BTU. At 100% efficiency (which is not possible) one gal of propane = 27 KWH. Older furnaces were 80% efficiency, newer ones are 90 to 95%.
Thermostats for heat pumps are two stage. When the difference between the setpoint and the room temperature is more than � 2�, the auxilliary heat is also turned on. The longer the strips are on: the faster you loose the efficiency that you bought a heat pump for.
Bill in WNC mountains with snow on ground for 61 days (very unusual)
