>I'm still pretty new to turning, but have been practicing. I'm having trouble making consistent V cuts. As I deepen/widen them, I almost always end up with less than a perfect point at the bottom of the V. I end up with a gap or "flat" spot that has little ridges of fuzzy wood on it. I'm sure you know what I mean. What am I likely doing wrong? In a book I have it says the skew chisel should always be 90 degrees to the wood in plan view, but rotated for each subsequent cut. But in videos I've seen the turner is clearly taking the chisel past 90 degrees and more or less angling it to match the side of the V. Any suggestions appreciated.
If I follow your question, you want to know if the handle of the skew needs to be at a right angle to the lathe axis (??). Answer = no.
The actual angle needed to get a nice, smooth cut and a perfect "V" all the way to the bottom will depend on how deep the cut is, how wide it is (the angle of the sides) and the steepness of the bevel on the skew chisel. If the V-cut is steeper and narrower than the bevel on the tool, you won't be able to get to the bottom of the cut.
Keith Rowley's book, Woodturning; A Foundation Course is a good source, but you might benefit from a good spindle turning video. Check out Alan Lacer's presentations on the many uses of skew chisels -- he's a great teacher.
>To make a V cut with a skew I use the long point down. You have to make a cut from the right and then the left. for example when I cut the left side of the V I aim the bevel on that side of the skew so that it takes a cut as wide as I want. Then I do the same on the right side with the right hand bevel.
The motion is sort of an arc. I touch the wood lightly with the point and then lift the handle so that it cuts down into the arc. the handle will be to the right for the right hand side of the V and to the left for the left and side of the V. The further you move the handle left and right the flatter or wider the V.
You can even cut a curve sided V by moving the handle left or right while you lift it up to make the cut.
Hope that's clear. It's simple to see but hard to talk about. Take a scrap of wood and just cut a bunch of V's. small ones, wide ones, deep and shallow. By the time you've cut from one end to the other you should be pretty good at it.
I use the same technique to face off the ends of piece or to undercut the bottom of a goblet. The skew is very versatile once you learn to use it.
>I agree with your book. The skew handle should be as close to 90 degrees from the wood as possible. This is how I make V cuts: With the handle 90 degrees to the wood and down about 30 degrees, I then lift the handle to make a slicing cut straight into the wood at the point of the V. I then tilt the tool a few degrees to the right and make another slicing cut which goes down into the original V made by the first cut. I then tilt the tool a few degrees to the left and make another slicing cut, which should slice down into the bottom of the V. With a little practice this becomes very easy. I've been doing it this way for years and was pleased to see that Alan Batty does it the same way.
I see that you're from Denver -- are you a member of the Front Range Woodturners? If not, I would highly suggest becoming one -- it's a great place to meet people and ask questions. We meet on the first Tuesday of the month at Rockler, 6:30. (See link below). (Front Range also has mentoring sessions monthly).
Though I used to prefer using the skew to make v-grooves, I've come over to Cindy Drozda's/Stuart Batty's ways of working -- I use a pointy spindle gouge instead. It's much easier to control and see the angle of the groove you are making. For example, if you know the bevel angle of the tool, (40'), holding the gouge perpendicular to the wood will net a v-groove with 40' angled sides.
If you are bent on using the skew, (which is definitely good practice to learn), remember that you are making the cut with the side bevel that the wood is nearest, and you need to estimate the angle using that side. Arcing the tool into the wood, point down, envision/watch where the tip travels, and estimate its arrival at where you want it to go -- the sharp V at the bottom. It takes practice. If you are getting fuzz, it sounds like your cut is ending up short and you're not continuing all the way to the bottom, OR (if you are getting a catch), you are twisting the tool out of alignment.
For additional viewing instruction, I HIGHLY recommend seeing Cindy Drozda's "Finial Star" DVD -- she gives an excellent primer on spindlework technique. (http://www.cindydrozda.com/Assets/html/Portal/DVDinfo.html)
Finally, as an ambassador of the Rocky Mountain Woodturners, please allow me to invite you to our club meeting as well. In March, Stuart Batty, woodturner extraordinaire, will be demonstrating. We meet at 6:30, Woodcraft store, Loveland, CO (http://rmwt.org/), Thursday, March 4th. (First Thursday after the first Tuesday).
>When starting a cut one way is to sight down the bevel to make sure the angle is just right before the tool touches the wood. After a few thousand "v"s this becomes second nature but is still handy with facing cuts.
>Thanks for posting that - it finally seems to make sense to me, maybe because it was sort enough for someone who is ADD like me to be able to pay attention long enough to understand it. But then again, the very good viewing angles didn't hurt either. Thanks again - now to find my skew
>Here's a 20 second video clip of v cuts being done.
When I look at it, it seems that the handle is at right angle to the lathe but the handle is slightly rotated left and then right to cut each side of the v.
