THE WOODRAT IS BACK!
Ebonizing cherry?
Ebonizing cherry?
Ebonizing cherry?
Dave Belser
>Looking for a high quality, high chance of success method for ebonizing a cherry (spindle) turning.
I have - gesso, lacquer, India ink.
What do you use and how? There is a fair amount of end grain on this turning.
- Dave
Re: Ebonizing cherry?
Donna Banfield
>Dave, I have used two of those three -- India Ink and Gesso. Results: there are different 'grades' of India Ink, and not all cover as well. Gesso is pretty thick stuff, and you will need to buff or lightly sand it out after it dries. May need several applications. Gesso will not soak into end grain as much as the India Ink.
Here's another option, which I have preferred to the above -- Fiebing's Black Leather Shoe Dye. It's a thinner consistency, so you won't have to sand/buff out the lines and reapply like Gesso. I get mine from Turtlefeathers, in North Carolina.
Don Evans
>I would think the ink would be best way to go. As you mention end grain the ink will go into very small voids where the other products you mention will tend to lay on top. One big problem with black is it will show every little variation in the surface.
The other question would be have you put anything on the wood like fillers etc. that could interfer with the product used?
I don't know of anything that is blacker than india ink so difference in end grain absortion and other grain direction should not be as prominent as it is with other type staining.
Take a piece of scrap and sand side and end grain and try the ink on it first.
Don
Don Evans
>The Leather dye should work well also. Donna is very right about the ink quality. I believe the leather dye (I have some but too lazy to go to shop and look) is OIL based I think. Ink is water. Don't know what your putting on top but could make difference.
If I had to guess I bet your gonna use lacquer? Don't think it will make any difference with it.
Don
I use leather dye too.
>I do all my ebonizing with black leather dye I bought from Tandy. Rarely to I need to do a second application.
Tom
fgvanatta
>I've always had excellent results with India Ink.
Frank
John Jordan
>Feibings Leather dye as Donna said. It is alcohol based and dries quickly, and only requires one application. I've made hundreds of pieces using it, and have tried everything. India ink will work, but it's not a very economical way to do it, and it is water based. I use India ink for touch-up on the rare occasion I need it.
Feibings can be gotten from Tandy Leather as well, and you want "USMC Black".
John
Thanks All
Dave Belser
>It sounds like leather dye is the way to go.
I'm need to get this done this week, so I might just use the ink I've got. Any chance Michaels or Wood craft caries that brand? I'll check around.
Donna, do you have any extra?
Worst case I can use the ink.
Mike Mills
Mike Mills
>I'm not sure if Michaels does but Hobby Lobby here does (Michaels probably does). It does not say Tandy Leather on the front but it does say distributed by Tandy on the back. It is USMC black.
Mike
bob davis
>i spray krylon semi.flat black. followed by semi-gloss deft. absolutely fool proof
Dan Oliphant
>John, does this leather dye work well for coating the ID's of hollow forms turned from a porous wood like Ash without bleeding through the wall?
Re: Thanks All
Donna Banfield
>Dave, call me.
>Dan I don't remember what wood it was that I had problems with but it did bleed through. It was a pretty thin piece and I think it was a soft wood but just don't remember. Analine dyes will also, had it happen on a platter. I would probably use the Gesso if I thought would be a problem again. I wanted to try one and seal the outside before dying the inside but haven't had the opportunity to do it. Hollow vessels aren't my thing so I only do half a dozen a year.
Bill Grumbine (Kutztown PA)
>Two words - Rust-Oleum. No, make that three - GLOSS Rust-Oleum.
turtlefeathers
adrien
>"All we carry is Angelus leather dyes and leather paints"
John Jordan
>No, it's impossible to segregate dye areas. Milk paint doesn't soak into the wood and might be the way to go.
John
Dan Oliphant
>Thank you sir, I guess that is just one of the down sides of Ash. I have had success with rattle can black after masking the outside diameter. Will still try the leather dye out though.
Jennifer@Indy.USA
>I would add to John's reply that you might try black gesso (any art supply store) as well. it's not quite as "chalky" as the milkpaint and doesn't penetrate like the leather dye does.
Jen
