REAL MILK PAINT
Exterior Door Hinges
Nick Tuzzolino
>The exterior door hinges on my lathe room (barrels exposed) are supposedly brushed stainless steel. After two years they are getting pretty oxidized. I'm sure they can be steel wooled or otherwise cleaned, but how do I keep the rust from returning (or at least slow it down)? What kind of protection can I give them?
Re: Exterior Door Hinges
Rob Wallace
I would try spray lacquer or spar varnish...
Rob Wallace
Tery Scott
>If not in a prominent line of site id apply a clear grease or spray with Crc once a month
Or beach home is 50m from the spray line and I spray them every time we visit with a marine grade crc
another think I have tried is sprayed on silicone
Jim H
>Don�t know about the finish, but as a former locksmith please make sure your hinge pins are not removable. If they are, you can lock the pin in place with a roll pin from the open side of the hinge. You can also put a pin in the frame and a receiver hole in the door edge to hold it in place if the hinge pins are removed. I came across this weakness almost daily, fixed thousands of them.
Nick Tuzzolino
>Jim: I did this before ever installing them. I buy my hardware from a regular door supplier and had them tap into the pins form me. Thanks for the tip though. Most people are wide open for burglars.
Thanks all!
Nick Tuzzolino
Jim H
>Glad your secure, hope the 1st thing you try works.
