>All are true. There is a picture of the one I use on my website at the link. Another big advantahe was that it was cheap, and it does the job. I have been using this for 10 years, so there is no question about durability.
>How does the square frame not interfere with the laser. I would have to see a photo. The ones I've seen still have a beam over the top and the laser would be blocked by that as you go past.
I think round has better placement for more wheels but it depends on where you want the wheels. 4 wheels coming in from the corners would be the same on a square. You can use a lap joint that is pin so it opens up like a big C and then you can install and remove it even with the tailstock in place. That's how my next one will be.
My next one is going to be made out of steel. It's much more rigid and I now have the tools to do it. I'll probably make it 8 sided and make it so it has a piece that can be removed from about 11 oclock around to about 4. This will let me use it as a bowl steady with 2 wheels on that side. Of course while I'm building one I might as well make a dedicated bowl steady as well as a spindle steady and hollow vessel steady. It would be hard weekends worth of work but then I would use them for the rest of my life.
>I was really just thinking out loud. I figured that there is much less framework above the steadied piece with a square frame, making interfence with the laser less likely.
>Karl, the biggest advantage of the H de Vries square-frame or vertical-post steady is that neither the carriers for the wheels nor the wheel mounts themselves are cantilevered. That is, both are supported on both ends.
This arrangement gives a steady that is surprisingly strong for the size of materials used. I built one using 1/2" plywood for the vertical posts and its strength amazes me.
I agree that it may be possible to arrange it so that a laser could be used without having the top wheel carrier getting in the way of the laser. Of course, this depends upon the specifics of the laser and wheel carrier.
And, you can remove it without having to remove the tailstock.
If you build one, put two wheels on the top member for a stronger steady.
>Doc. why can't you build the vertical post so they can be moved up and down? That way they would not be in the way of the laser arm. If the bottom board was slotted the post could side. It would take another set of knobs but may work ok.
>Katherine, the only reference I've seen to this type of steady (other than what is given on Russ's site) is one the website of Herman de Vries. The url is
Once you get to his home page, scroll down through the items on the left to Tools and Tips. Click on that, then scroll down to find two different versions of the steady.
Dick, I have not considered making the vertical posts movable. When I built mine, I concentrated on getting as strong a connection as possible between the base and the plywood "posts."
Now I'm going to try to include the link to the website. Wonder if it will work?
~Doc PS: Well ! It seems to be working. In fact, with Two clickable links.
