Shop heat and finishing
Paul Zerjay
>Anyone know of a good way to spray lacquer in the winter time without blowing yourself up? Here's what I've been doing:
Turn all day using a gas fired heater. After about 4 hrs the shop is a nice 65 degrees. Turn the heater off. Spray lacquer on the lathe turned down to 50 RPM's. Go back to the house for about 20 minutes. Return to the shop, and spray another coat. Repeat a 3rd time. By now the shop is too cold to spray any more, and also too fumy to fire the heater back up. I don't like oils, and I refuse to use poly. I'm thinking I can jury rig the BBQ rotisserie and spray in the basement of the house. My wife won't mind since I gave her such a nice Valentines day gift. ;)
Re: Shop heat and finishing
>Paul I have the same problem. I usually open the door and spray toward the outside. If the humidity is high I have problems. I've switched to minwax wipe on poly for now. It doesn't look that much different than spray lacquer to me. I now the old poly that I used to use was very cool or blue looking and just killed Walnut's color. The minwax doesn't seem to do that. If you don't like the poly try Birchwood Casey's true oil. You can get it at gun stores and usually Walmart. I believe it's a varnish based wipe on finish that is very easy to use. It builds faster than Minwax poly so if you like really glossy it's a good finish. It is a lot warmer color than lacquer of the minwax.
steve worcester
>No real solution. Spray three coats and wait until it is warmer or you are in the shop again and it has been warmed up.
Depending on the lacquer, you may not want to spray more coats before it has time to out gas anyway. Too much trapped solvents lead to issues, so 3s good. Let it dry some and wait for the next occasion. Don't rush a good finish.
bill crommett
>I spray with the dust collector hood (8 in.) up close and on. It is approx 8 ft. of flex tube from the hood to the blower, and by the time the spray gets to the blower most of the fumes have either settled or have been diluted to the extent that nothing will explode. I have been using this system for ten years, and have never heard even a slight pop.
Steve Kubien
Steve Kubien
>Try an electric heater when it is time to shoot lacquer.
Texian
>Good advice from Steve W. My shop has electric heat and A/C, and/but still prefer to let three lacquer coats dry overnight before building additional coats.
