Bandsaw bowl
Bandsaw bowl
Bandsaw bowl
Wow not sure what happened. The first post put 6 images of this bowl on the site. Glad I previewed it.
This is my first bandsaw bowl in very long time. I saw this on youtube the other night and had to try it. You cut put two boards together using a sliding dovetail. Draw your circles for the bandsaw cuts. Pull the boards apart and cut the half circles. Glue the rings together, then stack the rings up to form the bowl shape.
This was scrap wood and fought me. I should have tossed it but I figured it was just an experiment so I persisted. I accidentally turned the bottom so thin you couldn't even measure it so I added an extra piece to the bottom.
OK i've almost warmed up, time to get back out to the shop.
