Poll: How many shops have you had?
Steven Antonucci
Steven Antonucci
>Growing up, My grandfather had a very small workspace in the basement of our three family home. If it was 10'x10', I'd be surprised. My family is still in that house, and will no likely live out their days their. 40 odd years, one shop.
It got me to thinking: How many shops have you had?
We have been in our house 15 years, and I am in my second space in the same structure. Before kids, out downstairs was my shop (and man, do I wish it was again!) It isn't any bigger than my one car garage shop that I currently have, and I have been in and out of plans to expand our house and/or add a shop. Barring some financial windfall, that probably won't happen.
So let's say I have had two shops, and lusted for a third. How about you folks?
steve
Re: Poll: How many shops have you had?
>My first shop space was in a one car garage with gravel floor and not door. I made a work bench that folded up against the wall and locked in place. I only had a saw, Router, Jig saw, a square, chisels, and a block plane and a few clamps. They were all stored behind the locked workbench top.
My second shop was in the back bedroom of a 2 bedroom apartment. I masked off the air return to cut down on the dust, covered the carpet with pressed wood with duct tape over the joints. I had a shopsmith with planer, jointer, and bandsaw. I built a support system that would let me rip up whole sheets of plywood on that thing. I told all of the neighbor if I made any noise that bothered them to call and I would stop. They never called, even when running the planer, amazing. Fortunately the landlord never came by either.
my third shop was in a very leaky basement. I had to constantly clean my tools. I built up some of my hand tool inventory during that phase.
my 4 shop was also in a basement but this one was dry and nice. A little small but I sold the shopsmith and bought some stand alone tools along with a Delta 46-715. I had constant vibration problems that I thought was me and my poor turning skills. It broke in the middle of a project I had to finish so In a panic I ordered a Nova Comet which was the precurser to the Jet mini craze. My turning improved overnight. I then purchased a basket case Jay-line lathe that needed parts. I was able to rebuild it with the help of the machine shop tech at the University who let me use the equipment and put up with my dumb questions.
My 5th shop was after I seperated. I rented a house with a basement that had a creek flowing through it. It actually worked pretty well. It was all underground level so the temperature was fairly easy to warm up in the winter. When I moved in I asked the landlord if it was OK to do some woodworking down there. He said fine. One day he stopped by and saw how much woodworking I really did and how much equipment I had. He said, boy you really do woodworking down there. I stepped up to the Nova 3000 while there. I also purchased a Carbo-Tec mini so now I had 3 lathes.
Now I'm in my 6th but probably not last shop. A 2 car garage that apparently needs to be bigger. I stepped up to the powermatic and also purchased the Smith lathe/mill to do more metal work. Also bought a forge and I'm slowly learning some blacksmithing. I built the spring pole lathe which is also stored in there. I'm now up to 8 lathes if you count the Dremel lathe and 2 really old spindle lathes.
Jeff Brockett
>I have moved 16 times (In retail world we didn't do spring cleaning we just moved!) and my shops have been in closets, basements, garages, 10x10 outbuilding and now in what I hope is my last shop a separate 1000 square foot woodworking shop with an attached garage - you need a place to store all the wood gloats you collect! Shop has central heat and air, but loml put her foot down about it having a bathroom - she said that I would never come to the house if that was included!
Carol Reed
>Lost count. Just looking forward to the next one! Hopefully this summer.
robo hippy
>Well, for woodshops, I had 3. One in the basement of a rental house, another in a 400 sq. ft garage where it was so tight you had to open the door if you had to pass gas, and now a 24 by 36 pole barn that is insulated, and has some heat. I did have a dedicated room at a house once for building model gliders in my days as a hang glider pilot (I am a ground hog now, heavy sigh), and 2 shops in the days when I made custom footbags, know to most by the brand name 'Hacky Sack'. I would really love to have at least 2000 sq ft if for no other reason, to be able to have work shops.
robo hippy
Jim Shaver
>I've had one, it has been good and bad for me, Good in terms of my space to learn, bad that it doubled as a storage place for "foreign shop" items. My next one will be dedicated, shop only... less machines, an assembly area and a least two work benches....
Brad Vietje
Two -- planning the third.
Brad Vietje
>I started turning in my former garage in Thetford (kept the car outside -- the "Garage" was for Turnin!) No heat of any sort. :(
Then moved to Newbury and currently turn on a 6' x 14' concrete slab between the horse stalls and the former sheep stalls -- the only concrete slab in the building. Open to the rest of the barn, no real heat -- just an infrared lamp directed near me from above the lathe. I use another stall for the bandsaw, and a 14 x 14 stall for wood storage, as well as household garbage cans & recycling. Not ideal conditions, but I make do. :(
Currently living in a small house that will be my new shop when the new house is finished. A former slaughterhouse from the late 1800's, it has a built-in crane that will come in handy for lifting log sections up to the spindle. It also has a woodstove for heat, so for the first time I'll be able to work in a heated shop, and burn my scraps for heat. Main building is 33 x 19 inside, plus a 19 x 11' shed for wood storage and processing at one end. Should be ready this fall... :b 8)
Here's the crane -- a big 9' diameter pulley and 12' long shaft fitted between the vertical posts -- ignore the ceiling fan, which will be history very soon:
Can't wait for the new shop (oh, yes, and the new house will come in pretty handy, too!).
Safe spinning,
Brad Vietje
Newbury, VT
keith zimmerman, Normal, IL
>If you include the closet I turned in that was in the apartment I lived after my divorce, then I'm currently in my 3rd.
keithz
>Shop?
First was a garage or portion thereof.
Second - 1/3 of a basement.
Third - 1/3 of a different basement.
Fourth (and current) - more that 1/2 of a basement.
Wally Dickerman in Arizona
>I've had a bunch of shops. My first was a sort-of partitioned off corner in the barn. Not a cow barn, but more of a farm equipment barn. I was 15 years old and had just acquired my first lathe. That was in 1936. Since then I've had basement shops, garage shops, One was in a spare bedroom of a house we rented for a year or so in the 50's.
After I retired in 1986 my wife and I sold our house and moved aboard our boat. No shop there, so I rented a building 4 miles from the marina. For about 10 years I did a lot of turning between cruises. My present shop is a way-too-small shop in a partitioned off double garage. It's a bit crowded but I have all of the equipment necessary for a turner.
Wally
ihmserv
>shops 3
first was a 8 x 13 porch area no heat and I had to open a window to rip an 8 foot board.
second was 1/2 of a basement 12 x 25 area low cielings and leaked in heavy rains.
current is a 25 x 28 detached garage ( never to see a car while I live here :D ) heated only when I am using it. but could be bigger as I had to add an 8 x 10 storage shed out back to store turning blanks.
IAN
Steve Kubien
Steve Kubien
>Of my own? I am in a 10x20-ish garage and it the only true shop of my own I have ever had. When we lived in an apartment, the dining room was my shop and I actually built a few bookcases on the dining room table (wife worked days, i worked a bunch of nights. Shhhh, don't tell her).
Carole Valentine
>Two. First was a 2 car detached garage and then my new shop which was built in 2008.
Keith Tompkins
Re: Two -- planning the third.
Keith Tompkins
>Wow Brad...even a toilet! Now THAT'S a shop!
Keith Tompkins
Keith Tompkins
>Hey Steve, My first shop was a utility shed behind my mom's house. I bought a Rockwell table saw, Dewalt radial saw, and a Rockwell radial drill press at 18. Still have the Dewalt and the drill press,the table saw was junk. I was working at a cabinet shop; they let me bring scrap pieces of wood home to work on. I rented a shop in Sharon, CT, with a fellow woodworker, but that didn't work out. Then, I became partners with a guy I worked with, and we set up a shop in Kent, CT. Nice, with a real spray booth. That lasted for quite a few years, but I'll admit..I'm a PITA to work with; we went our separate ways. I went several years with no shop at all, then a shop in the basement of my first house. Always flooded. Arggh. Now, by shop is my basement, as much room as I need, but really want a detatched shop with solar kiln.
Del Williams - Chapel Hill NC
>I have had three shops of my own plus the shop I learned about wordworking with my Pop when I was a kid. My first "formal" shop was a garage in Memphis - it did not house vehicles so was only used for my shop space. Second was a shop constructed in Auburn AL. that could be changed to a garage if necessary - don't know what the current owners have in the building but it is still standing. I spent eight years in that space. The third is our current home with a 90 X 60 space with heat/AC goin on 11 years here. Life is good.
Four so far
>My first was in the basement of my parents' home, back in the late 50s/early 60s. That's where I caught the woodworking bug. We had a tablesaw, radial saw, lathe, scrollsaw, bandsaw, grinders, routers, two drill presses, portable power tools and a ton of fairly beat-up hand tools, mostly passed down from my grandfather.
After college, I outfitted my first custom commercial shop in a small barn on our rental property. It was spacious and ultra-rustic, but I built all my early commissioned work there and launched my custom woodworking business.
The third shop was at our current property. It was a two story bank barn with the heavy equipment in the lower level and lighter machinery, veneer press and assembly and workbench area upstairs. It burned to the ground in 1999 and I rebuilt my current shop on the same foundation later that same year. Here's a shot of the rebuilding. That's Frank Klausz lending a hand.
Being out of the woodworking business has made it difficult to develop my shop to the levels of tooling and efficiency I had in the earlier shop. It's harder to justify new equipment, tools and systems when you don't foresee much future need for them, especially as you get older and start looking ahead to the golden years. I can't imagine not having at least a bandsaw, a drill press and a lathe, though.
Frank Klausz In A T-Shirt!?
charlie belden
>I was certain that even his pajama top would be light blue - and with a starched and pressed three button collar. I'm stunned to find that he owns, let alone wears, a white T-shirt that God and everyone else can see. I'll have to really examine this image in PhotoShop for evidence of tampering.
Keith Tompkins
Re: Frank Klausz In A T-Shirt!?
Keith Tompkins
>He's gonna mill that 2x4 into veneer, that's my guess.
