pen vise, PSI Woodworking
>Anyone use the DRILLCENT3 pen blank vise from PSI Woodworking? I bought one a few years ago and only used it occasionally.
It worked fine for a while then began to get sloppy and lose it's center often. Examination showed the small threaded center rod was not threaded tightly into the vice jaw. I tightened the rod by hand and tightened the lock nut but it quickly loosened again. Closer examination showed the threads in the aluminum vice jaw appeared to be stripping. The threaded rod itself appeared to have a significant taper ground on the end allowing only one thread to engage before the end bottomed out. Seems like a design flaw to rely on one thread in soft aluminum.
Since PSI will only fix it if under warranty (and I have no idea where the receipt is), I repaired it by grinding away most of the taper on the small threaded shaft so more than one thread will engage in the soft aluminum jaw and tightened it securely.
Anyone have this vise and have similar problems? If so, was there a permanent fix?
