Lignum vitae chemistry
>When I've turned lignum in the past it would start brown then turn green, presumably as it oxidized. I assume certain finishes would slow this greening.
However, what if I want to make it turn green faster, does anyone know of a method? Chemical oxidizer? Will it still eventually turn green regardless of the finish? I was planning to try a CA glue finish.
Re: Lignum vitae chemistry
Re:John- Lignum vitae is so oily I wouldn't....
JamieDonaldson
>... apply any finish other than a good sand/buff/wax. I had a nightmare time trying to use an oil finish once, and had to finally remove all traces and start over.
My experience
>Thanks, you're right about the oil. Really clogs sandpaper.
I used a shellac-based friction polish on some lignum vitae magic wands I made last winter and it is still in good shape. (These are great to hand to kids along with one made from holly or cherry and tell them about the heaviest wood in the world - the difference in weight is amazing.)
I put three coats of CA on some pieces today - I'll see how it holds up and if it still eventually turns green under the finish. The shavings from on the lathe were very green after just an hour. Maybe I should try not to be to impatient and let the pieces sit out in the air for a while.
Re: My experience
Jorge Casta�eda
>John,
You may try putting it in an ozone environment, that should hurry things up,
In my experience lingum vitae eventually sets for a brown, the hearth wood, the sap wood remains cream color. The only greenish looking one I came across, I got from our friend the Monk at the Higher Ground last october, have not figured out what to do with it yet.
I got a long time ago some that came from Guayana (sp?) was lighter in color than the one I got from Mexico, so maybe there is a chance that they are not the same species, but several that get sold as lingum.
The only finish I put on them is beeswax and then buff it.
Jorge
Carole Valentine
>I agree with Jamie on the finish...no finish is best on that wood (maybe a little R wax). I can't believe you are impatient for it to turn green - it does it practically as you watch! Stick it in the sun for a few minutes. Seems to me that it turned back to brown if you put it in the dark. What I had was Argentine Lignum Vitae.
