This is the result of turning that stack of maple veneer I posted the other night. The size is about 3 1/2" x 5 1/4". This one has 5 ribs/spacers that are parallel across the form, alternating 2 / 3 on each layer. This causes the veneer to undulate up and down.
>Don it is an assembled stack. No notching involved. The layers of veneer are stacked with the sticks and then I steam and compress the whole mess, the result being a cylindrical assembly. Once that is done I turn the vessel form.
>Paul, this is some of the work I've been doing while exploring "supported" turning. I build up structures and then use wax or ice to support them while turning, melting away the support when finished.
>Dave that's amazing work, and for a new turner like myself looks almost impossible. How do you turn it?? I mean how do you attach it to the lathe and how do you support it? Do you cut out the inside cross members before turning, or turn them out on the lathe? Basically, how do you do it????
>What a great idea and great turnings! When I saw your stacks earlier I wondered what crazy thing was going on! Talk about unique.
I've imagined ways to support things while turning but only thought of things like plaster - I never thought of using wax! But I don't know how you would use ice without a pretty cold shop!
Thanks so much for showing this. (And I'm sure others like me would love to see more photos of the preperation and of the turning in progress.)
Another round of applause! You have created a new path where none existed. I hope you continue along this path and, please, take us along for the ride. Looks great! Now, you need to write an article for American Woodturner!
>Now that is really thinking outside the box, outside the bowl, outside the vase, outside the norm. Your mind works a little different than a lot of people doesn't it ! (I mean that in a very good way!)
OCD stands for "Obsessive Compulsive Disorder", like a number of clinical disorder terms - I think it is overused and often mis-applied. I've read that 6 out of 10 people exhibit OCD traits.
For me, the Obsessive (and possibly Compulsive) seem to apply to a lot of my work. I've always been drawn to highly repetitive patterns and structure (tiles, branching etc). I tend to make work that involves "pushing" or repeating some aspect to what some people would consider monotonously boring levels. I've been trying a lot of different layered structures and it evolved into the ones presented here, which are not much like I imaged and set out to create. I'll keep trying to create that original, imagined idea - the "problem" is that along the way I find other ideas. Some would consider this obsessive
Compulsive - I don't think that there is a lot of "compulsive" it what I do - I don't *have* to do it. But it pleases me and becomes almost meditative when I'm doing it. The closest it comes to being compulsive is that if you put a small pile of identical or similar things (toothpicks, stones, paperclips, seeds) in front of me I will probably start arranging them and playing with them without thinking about it.
True OCD is when it interferes with a daily *normal* life - you can't leave your house if you came down the stairs and "forgot" to tap every third spindle. To the point that you will go back and do it again until you get it right.
There is a great exhibit at the "American Visionary Art Museum" in Baltimore that is titled "Obsessive Compulsive Delight" check it out if you get a chance.
I don't think creativity is compulsion, my Mother used to say: The fool that persists in his foolishness becomes wise" , so whatever is trying to come out, let it flow...
Looking forward to more.
Thanks
Jorge
I'll visit the museum later, I could not get in, way too slow...
>Great. It will be interesting to see where you go with this. That may be my favorite museum in the world. I haven't been in a while. Probably not too crowded today.
>I couldn't really picture the result of your stack when you posted it earlier. The result is wonderful. I understand the need for steam bending, and can visualize how it was done, but how in the world did you do the glue-up before the glue starts curing or the wood loses it's flexibility? Seems like it would take a lot more time to get the glue where it tacks the bent wafers together. I haven't ever tried steam bending, but seems like the wood would not remain pliable for long.
