Have a question? Ask Woody!
Finish for pepper mill and salt shaker
Jeff
>I am making a pepper mill and salt shaker for my brother and need some ideas on a finish. I have used a friction finish in the past but he is not too fond of it. I thought of using lacquer but then realized that it would be exposed to water and cooking oil. Right now I'm thinking of using poly but thought I would get some other opinions first. They will be made of cherry.
Thanks,
Jeff
Re: Finish for pepper mill and salt shaker
Steve Kubien
Steve Kubien
>I have used rattle-can lacquer with no complaints from clients. In fact, my Sensei has the first set I ever sold and he is a fanatical cook who uses them regularly. They still look good as new (over a year of hard use later).
Peter Lamb in SC
>I use Minwax wipeon poly 4-6 coats with good results. It comes in high gloss and satin. I find it a forgiving finish. Then buff and wax
Peter
Tom Vensel
>For this set that I made for ourselves I brushed on two coats of satin polyurathane and then used the beale buff system to smoothe out the brushmarks . They will get hard use and I wanted a finish that would take soap and water . Tom Vensel in snowey S/E Ohio
Doug Turner
>A demonstrator at our club who specializes in (and sells) peppermills uses several coats of Waterlox which contains a varnish. After the desired sheen is obtained he gives it a Beal buff without the wax. Water will spot wax and/or lacquer.
