McNaughton Bowl Saver Question
Ed Larson
>I'm still in the learning phase with my McNaughton Bowl Saver. Should the knife be on the left or right side of the T-bar?? I've seen pictures of it used both ways. It there any reason to use one side or the other??
I just learned that you extend the knife all the way to the handle to determine the correct height of the knife to be cutteing just at center. This is spelled out in one of the two sets of McNaughton instructions that I have but not the other. I have the standard set of knifes and just discovered that the knife goes in the middle slot not the left slot that I have been using. Again this is not spelled out explicitly in the operating instructions.
I'm interested in any methods that people use determine the knife depth to prevent making a funnel or a very thick bowl bottom.
