>I have recently constructed a vacuum chuck system. I put it all together only to discover I have a weakness in the bearing. The pump produces approx. 22hg on its own. When I test it right after the bearing it drops down to 15hg. Is this enough do you think? If not any suggestions. If I apply some downward pressure on the bearing it increases to about 17 to 19. Making me think that there is a flaw in the bearing (double sealed). Other than replacing the bearing, any suggestions?
>Without knowing the details of how your vacuum system is constructed it's difficult to make suggestions. Perhaps if you send some details via email I can offer some helpful ideas.
>Derek, I've made 5 couplers using double-sealed bearings, and out of 5 bearings, I found that 2 of them "needed some help" in developing an airtight seal.
First, be sure it is the bearing that is leaky and not a connection on the lathe side of the bearing. An indication that the bearing is leaky is having the vacuum reading fluctuate as you press on the black seal of the bearing at various points around the circumference.
Here's what I've found to be most effective. First, run the lathe at moderate speed for a minute or so with the vacuum ON. Then apply a modest amount of petroleum jelly (Vaseline) to the seal. Take a swatch of paper towel and twist it into a tight roll, then fold it over so that you can use the folded end to apply pressure to the seal while the lathe is running.
Turn on the vacuum and start the lathe at a fairly low RPM, like 500 or so. Watch the gage while you apply pressure to the seal with the twisted paper towel. Any fluctuation in vacuum means that you are close to the problem, and if you are lucky, the bearing will seal and the vacuum will rise to very nearly that of the pump without the bearing in the system.
This technique worked on the two bearings I had that were leaky.
I don't know if this is important or not, but I arrange a support for the vacuum line so that there is no sideways force exerted on the bearing.
To block the headstock spindle for testing, I simply insert a drive center into the Morse taper at the inboard end of the spindle.
More information about your system would be helpful. For example, what material did you use to make the body of the coupler? MDF or Plywood? Did you seal the surface of it with sanding sealer or polyurethane?
