Pfingst, not Pfizer
Pfingst, not Pfizer
Pfingst, not Pfizer
AndiWolfe
>I just realized that I've been writing Pfizer rather than Pfingst as the brand of micro sander I use. Pfingst is the correct brand name.
Re: Pfingst, not Pfizer
Carole Valentine
>Had to laugh at that Andi...Pfizer makes the ED drug! LOL (Can't type the name of it because Ellis' naughty word filter would grab my post)
AndiWolfe
>Hey, Carol - thanks for that. I had no idea about the brand name connected with a particular medicine. I delete all my spam unread and without the TV set going, I miss all the adverts. Now I have to stop laughing when I pick up this micro sander each time I use it ;-)
Caution! :-)
David Propst
>Don't use the sander sitting in a tub watching the sunset!
(Please forgive the stupid commercial reference.)
David
Re: Caution! :-)
AndiWolfe
>I don't know the reference, but I can imagine this refers to a commercial or advertisement for the implied medical enhancement discussed in previous posts.
Re: Caution! :-)
Carole Valentine
>LOL! Good one, Dave!
Nice to see you - where have you been? Are you doing any turning?
Re: Caution! :-)
David Propst
>Hi Carole!
I graduated in May and started working as an NP in July. Got a great position in an urgent care. Still catching up in 3 years of lost family time and home projects and repairs. Roughed out a few bowls recently and have started checking in here. I talk with Ms Shirley periodically to keep in touch.
Good to see so many "old" names around!
David
Re: Caution! :-)
Carole Valentine
>Alright! Glad you are back. Congrats on the job...you certainly deserve it after all the hard work you put in. :)
Dick Hines
Re: Caution! :-)
Dick Hines
>I just don't get the bath tub and sun set thing.
Glad to see you posting again Dave.
Tubs and Sunsets
David Propst
>One the the brands of medication referred to has several ads showing a couple sitting outdoors in side by side bathtubs holding hands watching the sunset. Not enough light to use a micro-sander properly and a huge electrocution risk!
Barbara R Dill
>I'm so glad that is has been snowing and that I have been spending my time looking at this site. This is so entertaining. It is also great to see the questions and responses from all. I think I've worked my way all the way back to 12/09...lots to read!!
Re: 12v won't even make your hair......
JamieDonaldson
>...stand up, let alone any other anatomy parts! (;-D)
depends on the current
>12v is easily enough to trigger muscles to contract. I learned about this in elementary school when I built a kymograph and triggered frog muscles with a variety of low-voltage sources.
Brad Vietje
Yo BABY!  You got that right!
Brad Vietje
>I have no doubt the small 12 volt system being discussed would be no problem -- 12 volts at 0.5 Amps is just 6 watts.
However, I deal with 12 volt battery banks powering inverters up to about 3kW, so if there's a momentary surge up to about 4,000 - 5,000 watts and the actual battery voltage has been drawn down to 11 volts, that's somewhere in the neighborhood of 400 Amps, which could stand up -- and then lay down(!) all your body parts!
While I would usually recommend a 48-volt system for such large loads, I have some 12-volt off-grid customers with older, inefficient well pumps (they should swap out) that work in the 300 - 400 Amp range (that's DC -- that would be 15 - 20 amps at 230 vdc), so the inverter cables to handle that load are doubled up 4-0 copper, each nearly as fat as a thumb!
The whole point here is that not all 12-volt thingies, doo-dad's and gizmo's are safe to touch.
Safe spinning (and touching),
Brad Vietje
Newbury, VT
