I think I killed my chainsaw
Mike Foster
>We've had a spell of clear cold days, and after a downpour a few weeks ago, the amount of snow in the woods has diminished greatly. Perfect conditions to get up into the woods to retrieve a couple of maples that were blown over in a wind storm 2 summers ago. The rootballs were intact on these trees, and they were fully leafed out last summer, so I wasn't too worried about the wood. Spent Fri and Sat pulling these trees out with my tractor. The larger of the trees (20" log) had a hollow center. Big bummer. The other was intact but only about a 16-18" D log. Got them both out and bucked into 16' lengths (5 logs in all). I intend on having the wood milled by a friend into 1" wood for flat work. I could make a lot of bowls with that wood, but I am not into production work, and I hate to use it for firewood, so boards it will be.
I saved about 4' of each tree's base for round work and was just starting in on processing it and the chaisaw just stopped. Gas is OK, so pulled on the cord and found there was no resistance. It feels like the flywheel is engaging, but there is a total loss of compression. I decided to let the guys at the sawshop look at it rather than waste my time tearing into it. Cracked head comes to mind. I suspect the saw is dead, but maybe I'm wrong.
Slathered everything with sealer and called it a day. At least the logs are out of the woods and ready to be carted off to the mill.
