>Have any of you had your Kelton coring blade bend vertically? A fellow turner was over today and noticed that as we cored, the blade, which started out a hair above center, wound up significantly below center at the base of the cored bowl. The other blades in the medium set rest flat on a horizontal surface.
>Wow...what were you coring, Jack? My friend slightly twisted one of his blades (small or mini - don't remember which) which will make it not lay flat, but he just straightened it in a vise and it was fine. I may be wrong, but I believe the blades are made so that they will bend rather than break. Did you try to straighten it? I had a few huge catches when I first started learning to use the tool, but I have never bent one.
>Jack, like Carol�s friend I have bent blades down when I started in particular. They would twist and drop. They are easy to straighten in a vise with a Crescent wrench. Better to bend than break.
If I have one that is down slightly it does not matter, I just start a little high making sure the tip is on center when the blade is fully extended out of the gate.
>I'm betting the blade is twisted and is bent in the dimensions rather than just bent along the wider surface. Lay it on a flat surface as you have it and put a small level on it and see if the face is always vertical. Or you could put a series of small straight pieces of wood like 1/8" dowels taped to the piece and see it they are all vertical.
I took mine to a friend's shop and he beat them into submission. I INSIST that the knives must be a segment of a circle and when mine came they were sections of ovals. We reshaped them so they would lie on a piece of plywood that had concentric circles drawn on it and they work MUCH better. The blades are quite soft and were actually pretty easy to bend. Since them I have turned them up with a vice and big adjustable wrench.
>It is common for them to do that. With heavy use, no catches necessary, they will bend like that.
There is always a lot of torque on the blade as you cut, which is why they are in a gate, or support fingers. Not to worry, as others have said, clamp the handle end in a vise, and put a big adjustable wrench, or monkey wrench on the tip end, and torque it back into shape. I do show this in my DVD.
As to the shape of the blades, and not being segments of a circle, they are stamped, not cut from round stock. The bends can be rather inconsistent. The very tip isn't in the jig, so it tends to go straight rather than follow the curve of the arc. Having one of the plastic circle templates (I got mine from Craft Supplies), you can lay them on the template and see where they need to be tweaked to get them perfect. I do tweak the tip on most of my blades. As near as I can tell, this is the main reason they tend to drift as you core, and properly tuned, you won't need to correct by bumping the tool rest, or opening up the cut. This is some thing that I am still experimenting with. It has been frustrating because I would think that I should be able to make a core with one pass, with the only stops being to clear the shavings. The blades are longer than the other systems, and that adds to the flexing of the system, but I can think of no other reason other than the curves not being perfect.
Height is another problem. It is easy to start out at center height, but end up below. This isn't always because the blade is bent. If you have ever tried to remove the stub that is left with the core breaks out with your coring system, you will notice that as soon as the tip contacts the stub, it bends down a lot. I start out as much as 1/2 inch above center on big bowls, so that by the time I am at the bottom of the core I will be close to center height. There is a lot of flex in the blades, and the tool rest. This is by design.
I don't know how much I can say here on the forum, but I did a DVD about 2 years ago. Mostly because I use a lot of teaching tricks and tips that Mike Mahoney doesn't, and I thought I could do a better job. This tool has a big learning curve. If you want more info, contact me. It isn't sold through the catalogs, only from me.
