does anchorseal work on frozen wood?
karl jr
karl jr
Re: does anchorseal work on frozen wood?
Lan Brady
>Not at my house because the Anchorseal is froze as well!
Lan
Rob Wallace
Rob Wallace
>Not well, at least in my experience...
I sealed some walnut I cut from a downed trunk of a tree given to me about three weeks ago.... whacked it up into half-section bowl blanks with the trusty Stihl 260 Pro, sealed the ends with Anchorseal immediately after cutting it, and stored them in an unheated garage.....the temperatures around here (central Iowa) have really not ever been much above freezing for any length of time since then. The Anchorsealed ends are still cloudy after a few weeks (and are not the typical 'clear' wax film you get when the Anchorseal dries correctly). It does stick to the wood OK, and I assume the wood is sealed, but is doesn't behave as it does when the temperature is above freezing.
YMMV*,
Rob Wallace
(*Especially in a recent Toyota)
karl jr
karl jr
>So far this winter I have been counting on the freezing temps to keep wood from checking. So far, so good.
Brad Vietje
Funny You Should Ask...
Brad Vietje
>... Just coated some frozen wood yesterday, Karl. I have some 4 year-old, cryo-protected Anchorseal that I had never opened until yesterday afternoon. I was surprised that it was still good as new -- we've had -25 or so at least a dozen times since it was new.
I was also surprised how well the stuff dried and turned clear at roughly 25 degrees F. Only took about 15 minutes. I think if the wood is clean and relatively dry, or free of snow and ice, it should be fine.
Here's a photo of the coating going on...
And a few minutes later:
I also coated some frozen Grey Birch and curly Yellow Birch chunks and bowl blanks. To use up the Anchorseal I'd already poured into a little bucket, I added some more to the flat cut face on the largest -- the spalted Grey Birch billet, about 5 hours later when the temp had dropped to about 12 degrees. In the morning, it was still milky colored, and had ice crystals in or on the surface, so I'm not sure what sort of protection I'm getting there. Since I don't usually coat much of the flat face of the side grain, I am not concerned, but maybe 20 degrees and up is OK, but colder is questionable(?)
Safe spinning,
Brad Vietje
Newbury, VT
Re: Funny You Should Ask...
Jorge Casta�eda
>Hi Brad,
I have a bucket of the glycol formulation, and recently at 3F i did coat a couple big chunks of frozen yellow birch, but I did cut it two days after bringing it inside my "shop", it was clear a couple hours later when I went back in there...
