My band saw is wandering
Duane Wiedman
>For years I've been able to use the standard rip fence and make pen and stopper blanks that are parallel. A few weeks ago the wood began to drift away from the fence. I thought maybe the blade was getting dull so I replaced it with a Timberwolf 1/2" 4 TPI (the same blade that was on it previously). This is on a Jet 14" (JWBS14CS) saw. While I was at it I replaced the tires, the cool blocks, made sure the wheels were Co-planar, oiled up the bearings and reset them. The blade teeth are centered in the top wheel(I also tried it with blade centered). As you suspect, the wood still drifts away from the fence. It even drifts when I use a sled to cross cut the stoppers. Can anyone guide me to what I missed or what I should revisit? Thanks for any help you can give.
Duane
