Assistance needed in locating a tool
AndiWolfe
>I'm trying to find a small motor similar to the Pfizer micro sander unit. I'd like to modify it for taking some small carving burs for some fine detailing. Does anyone have a suggestion on where I might find such a specialized motor?
Thanks - Andi
Re: Assistance needed in locating a tool
Steven Antonucci
My first thought was RC car motors
Steven Antonucci
>I don't know the specs you need, but I think RC motors rev up pretty good and have some pretty good torque. They run in dusty environments, so they might be a fit?
Re: Assistance needed in locating a tool *LINK*
>Andi They have some really cool motor driven tools in MicroMark tools. Frank Sudol used to use their mini jigsaw.
http://www.micromark.com/
AndiWolfe
>Aha! The RC motor is what I was looking for. Thanks, guys!
How are you getting a chuck on that? torque?
Dick Coers
>I suspect those motors have almost no torque. They all run very high rpm and run through gear boxes for use on the cars.
Also no thrust bearings to handle load.
Dick Coers
JB
>why not turn a small adapter for your sander to hold the 1/16" bits
AndiWolfe
>The sander is one of those RC electric motors, too, I think. I found a double-ended pin chuck that should work for my needs. I'll post a follow-up once I play with this idea a bit.
steve worcester
>If it is a 12V motor, you can always plug it into a model railroad power controller (which works as a power source for it) and adjust the speed. I did that for a glass grinding "assperiment" that I did and it worked real well.
