micro sander - Andy Wolfe?
>Andi, you've mentioned the micro sander a couple of times and it does look interesting. Looking in the Sanding Glove catalog I see two versions of the Pfingst micro sander, one for $185 and one for half the price. A question (for you or anyone):
Is the only difference between the two offeringsthe speed controller? If so,
- Does the micro sander transformer plug directly into a 110v outlet or is a special voltage and/or connector needed?
- Is this type of sander best used with a foot switch?
It's hard to imagine a speed controller that is worth $95 so perhaps there is more to it than it seems. If the sander transformer plugs directly into a 110v outlet another speed controller may work - for example, I already have one intended for a router - it doesn't have a foot switch but one could be added inexpensively. I may call the sanding glove guy and ask, but info from real users is valued!
Re: micro sander - Andy Wolfe?
Bob Macgregor
>Yeah, or a pedal control from a sewing machine.
Rheostat?
John Kaner
>Doesn't a sewing machine pedal have a rheostat to control speed... I guess you can rewire as a dead-man switch...
marvin ewing
>I have one of the sanders I bought from Sanding Glove also. Had it for about 3 years. I bought a leather punch from Tandy Leather to cut the circles and bought double-sided sponge tape at a local store. Mine has a variable speed foot switch that is plugged into 110 but it transfers it into DC current for the sander.
Don Evans
>Are you sure about your wording on that last statement?
Doesn't the transformer that runs the sander use 110 v AC and that same transformer converts it to DC for the sander?
In other words you can plug the transformer into a wall outlet and run the sander without variable speed?
Don
>One web site indicates: Micro Sander includes a AC adapter, 3 sander heads. Many different grits of sand paper. This unit can be used with most foot pedals you have.
Note this does NOT state specifically that you can plug the wall-wart transformer into a speed controller. The type of AC-DC circuit in the transformer could prevent adjusting the DC voltage for speed control by changing the input AC voltage. From a photo, it appears DC output from the transformer may plug into an in-line connector to feed the sander motor. It doesn't seem likely, but i can imagine this could be designed so the foot switch/speed controller would supply variable DC directly to the motor with the AC adapter simply supplied for completeness. In any event, it would be pretty easy to make a DC speed control to put in-line if necessary for those of us to cheap to pay for the whole thing!
I found this picture:
(BTW, seems like everyone else is far cheaper than Sanding Glove for the same tool.)
Don Evans
>Sure, all the tech stuff you say is true but I'll know in few days as I ordered one.
Regarding price, I only found one other vendor that sold the thing and that was MDI up in Maine which I buy carving supplies from sometimes.
There price was actually higher but I think it was only $5.00.
Note that both vendors SandingGlove and MDI use the same part numbers for this.
One is MS100L which is sander without the variable control and MS200L with is WITH
the variable control.
I really don't see YET why variable controll would be needed for this, my experience has been that its better to run sand fast and let pressure against the wood be the control.
Faster running with much less pressure has always given me less deeper cuts especially with the rougher grits and removes lot of wood at that point in sanding with less work when trying to get the grit cuts out of the project.
Anyway, I ordered one of these things with the hope that it will cut down on what I usually end of having to do by hand with riff's and files or on small stuff.
Anyway, if interested, check out the rheostat foot controls at:
www.micromark.com
Don
rheostat for the sander
AndiWolfe
>John et al.,
I do have the foot/hand switch for this unity, but you could just as easily use the foredom foot switch or any other controller. I was using my foredom foot switch for a while, just so that I didn't have to unpack the one for the sander. I'm not using the foredom as much as I used to, so now I'm using the sander's dedicated one. I didn't notice a difference in the foot pedal operation. However, the sander's foot/hand controller allows you to choose a speed for when you use it as a hand switch.
>Please let us know your experience, especially if you plug it into a speed controller made for AC motors. This thing looks so useful for carving.
Don Evans
>John, I'll be glad too. Right now there are to many questions marks as there are several approaches they could have taken with this thing.
I really don't see at this time why they would convert it and run it with DC as AC would be cheaper and easier with this unit. I once had the idea of making a detail sander by using the "motor" part of a tattoo machine and I see this thing using that same principle of operation. But we could guess all day and still turn out to be wrong.
If I could find a tattoo hand piece cheap I would still like to pursue that angle as it would be easy to make it reciprocate and vibrate type motion to sand.
Anyone know of a source for used cheap one let me know.
Update to come soonest, thing hasn't shown up on porch yet.
Don
Re: micro sander -  technical answers
Don Evans
>I received my micro sander yesterday and got to play with it about 5 minutes last night. Here are some of the answer that John K and I were wondering about.
The sander itself is a stepper motor, you can feel the clicks when you turn shaft by hand.
It is a DC motor that runs on 12volts, the transformer that comes with it takes in 120 volts AC and converts it to 12 volts 1/2 amp to run the sander.
You can just plug the transformer into wall outlet and run the sander at 6500 rpm with no variable speed control. There is a two prong plug on the sander that plugs into the output of the transformer which you can reverse to change the direction of rotation of the sander shaft.
Regarding the foot switch. I didn't get it, but based on the sheet that came with the sander it implies that it is JUST a rheostat IT DOES NOT output DC to drive the motor directly, instead, you plug the transformer into the output of the foot switch which would therefore be AC. The rheostat would clip the AC on output therefore decreasing the voltage going into the sander. Here is quote from sheet: "Plug AC/DC Adapter into Rheostat or 110 volt wall outlet".
Only improvement I would recommend is to add a way to turn it off and on if not using the foot switch. They didn't do that so you have to unplug it to turn it off without the foot switch.
I personally don't see where variable is needed for this unit. I've learned that in turning or carving it works better to keep the speed up and control sanding action with how much you press down with the sanding paper. It works faster and with light pressure you don't get as deep scratches that must be removed with finer grit paper.
Don't missunderstand that last statement, I'm NOT saying you can skip grits, I'm simply saying it's easier to remove less deep scratches when using the finer grits.
Keep in mind that this is a DETAIL sander for small area's and it did a good job on some piercing I had waiting for it but it's not gonna have lot of torque but it had plenty for it's type work.
I'm suspicious this may be a motor that is used in RC hobby or model railroading. Some of the racing cars have some really hot motors in them now days.
Don
JB
>With the microsander, I find the need for slower speeds when using the smallest tube (3/16") otherwise I melt the foam off -- then I use my inexpensive 'wheecher' pedal to control speed. For the larger tubes, full speed is fine.
Additionally for sanding, I also turned some tubes and use them on my regular handpieces (foredom,dremel) applying hook/loop to the tips -- they also work very well.
The short body of the microsander is often the advantage to this tool.
Thanks Don, this really helps!
Molly Winton
technical answers - thanks
>Great. I may get one of the basic units and try it with the Foredom foot controller or the router speed control. In general I'm one that does better with sanding speed low.
From your description, I doubt it is a stepper motor. A stepper motor uses an electronic controller which feeds a series of pulses to the motor - one pulse moves the motor one step. The controller varies the speed by feeding the motor pulses at the right rate. These are wonderful for applications where precise rotational positioning or an exact number of turns needed but rarely used in applications that simply spin a shaft. You could not decrease the speed on a typical motor/controller by decreasing the input AC voltage to the controller unless the controller were specially designed. Stepper motors and controllers are also relatively expensive. You could easily tell if it's a stepper motor by connecting an oscilloscope and looking for a pulse train. I suspect it's a permanent-magnet motor, common for use with DC voltages, where the clicks you feel are just the magnets snapping the poles into place. Of course, I've been wrong before, many times!
Thanks, Don, for taking the time to write about this.
Re: technical answers - thanks
Don Evans
>John yes, you are correct. I didn't know what you were talking about at first and had to go back and read my own message. I don't know why I said stepper motor, maybe it has to do with the fact that I worked with them for 20 + years. Got them on the brain I guess.
I've got about a few of them (steppers) in spare parts that maybe some day I'll find a use for them. Maybe a CNC machine for inlay making some day!!
I hope that misspeak didn't cause anyone trouble. Personally it ruined my day.
Don
>Oh, I hope it didn't really ruin your day - it wasn't that important! I used to write software and we controlled stepper motors on occasion so with some familiarity once I started writing I couldn't stop! (My part of the systems was usually writing UIs and simulators for the hardware so I could test the function entire system before actually interfacing with the nuts and bolts.)
I wish I had some stepper motors on my shelf, but hey, probably a good thing I don't since there aren't enough hours in the day as it is.
You're welcome me lady
Don Evans
