Mahogany Question
Mahogany Question
Mahogany Question
Cgelnett
>My sister-in-law sent me a log they found on the California and Nevada boarder. They called it mountain mahogany. It is a very dark bownish red and it seems to be harder than most mahogany wood I have seen in the past. I has been laying around for a while the outside wood had turned gray.
I will add a picture but am traveling for work this week.
Thanks
Re: Mahogany Question
bill nixon
>So, what's your question?
Mountain Mahogany
Dave Staeheli------WebKitFormBoundaryRHbv7yP7o3x+b
>If you haven't lost it due to checking, you have a wonderful find. It is very hard, close grained, without dramatic grain and according to Stuart Batty, a good substitute for boxwood in thread chasing. In ages past, it was what they made rollerskate wheels out of. Best of all, "turns like butter". Unfortunately, difficult to get large pieces and prone to pith checking, even before cutting. Pith checks also tend to have a white fungus which shows up if you leave a bit of check in your finished piece. As you cut it up, think more about spindle turning or small diameter boxes. Makes great tool handles. If the wood is totally fried, it is used as a specialty smoker wood for jerky and such. When I can get get it, I absolutely love the stuff!
Cercocarpus spp.
>Mountain mahogany is actually not a mahogany but a member of the rose family that grows on high, dry ground from Oregon to southern Mexico. It is a small tree and the wood is very dense and excellent for turning. The sapwood is tough but the heartwood is brittle. It is very resistant to decay.
I wish I had some. If you can find a couple logs of it, wax up a piece for me.
Cheers,
robo hippy
>As said by Ellis, it isn't a mahogany, but is called that because of the color. Heart wood can be black, sap wood is creamy white, and the rest is a mahogany color. It grows in high desert areas of the western Mountains. I got a bunch a few years ago that was growing at 8500 feet outside of Las Vegas. With about 4 inches or precipitation, it grows really slowly. It was part of a thinning program for fire safety, and the Forest Service was going to cut it up for firewood. Hardness on the Janka scale is 18. Bubinga is 12, Lignum is 20. Specific gravity is 1.1 to 1.2. Fresh cut, in spring, the sap wood will move some, the heart wood doesn't move hardly at all. It is the only fresh cut wood that I have turned where I needed to wear a dust mask. Because of the density, I do sand up to 800 or higher grits. Generally the older stands are protected because it is an important browse food in the winter for the animals.
robo hippy
