Shop Fox Buffer
Shop Fox Buffer
Shop Fox Buffer
Dale Sherman, Manlius, NY
>Any opinions on the Shop Fox bowl buffer? Klingspor just sent out an email about it for $109. Anyone know if it has bushings or bearings? Any others I should consider?
Dale
Re: Shop Fox Buffer
Re: Shop Fox Buffer
Randy Johnson
>I seriously considered buying a dedicated buffer for a while. What I did instead was buy an adaptor with a morse taper that let me use the lathe as a buffer. It's a good and much cheaper alternative.
Re: Shop Fox Buffer
Re: Shop Fox Buffer vs. lathe-mounted buffer
>I have a lathe-mounted buffer now, but sometimes the lathe head gets in the way. I was thinking the long arbor would give me more maneuvering room. I have seen folks use a long shaft between centers with buffing disks mounted along the shaft, but that doesn't allow one to get down inside a deep bowl.
Dale
Re: Shop Fox Buffer
You might try making an extension. Frank Penta made one for me in just a few minutes (it's hard to get the guy to slow down!) He took a piece of wood about 8"x2+" square, turned a cylinder, mounted one end in a chuck, bored a small hole in the other, then mounted a steel threaded insert from Lowes, similar to this one:
The insert has a internal thread to fit the popular Beall buffing wheels.
The buffing wheel is fastened on one end and the other is gripped in a scroll chuck. This extends the wheel far enough to give you some working room away from the headstock.
Mine is made of sassafras, and of course Frank decorated it with some texturing and signed it so I can display it in my gallery.
Re: Shop Fox Buffer
Don Pencil
Re: Shop Fox Buffer
Don Pencil
>I believe you will find you answer here.
http://www.donpencil.com/WNTADAPTORShtm.htm
You can get from 3.75" to 12" away from the headstock.
Adaptors thread onto the spindle of the lathe.
Re: Shop Fox Buffer
Re: I was going to mention the Don...
JamieDonaldson
>...Pencil extensions I have used for years, but "some guy" beat me to it!
Re: Shop Fox Buffer
Re: I prefer the lathe
Steve Criscenzo
>I have both a dedicated motor assmbly for buffing (1700 RPM) as well as Don Pencil's adaptors for buffing on the lathe. I find I use the lathe more and more. The real advantage for me is the speed control on the lathe. Buffing with 8" wheels at 1200 RPM (rather than 1700) allows for a softer wheel that is not as likely to throw the piece I am buffing..
Steve
