>just back from vacation and I uploaded a few hundred shots from my camera to the PC. I am noticing that the image on the monitor is substantially "darker" than the image on the LCD on the camera. It looks underexposed on the monitor, but I know that the images are good because many of them were simple point and shoots in good sunlight.
Is there some simple thing I can do to adjust 300 pictures by 1 stop or so?
>I agree with Ron - you should check that the monitor is calibrated properly before messing with the images.
In the graphics business, calibrating the monitor, printer, and scanner was one of the most important things - you can waste a lot of time and still not get good results otherwise. I have a hardware device (Spyder) that fastens to the front of the screen to sense the screen and software to help make adjustments. However, you can get real close with tools available on the web which display grayscale steps to aid setting brightness and contrast, and color scales to help adjust color. Search for monitor calibration. If you have one of the Adobe product (e.g., Photoshop), you can run Adobe Gamma from the Control Panel to create a system-wide profile.
Note that you can get a pretty good idea if your monitor is close by displaying some web photos of closeups of people's faces.
If you do end up needing to adjust all the photos, the batch features of Photoshop and I think some other image editing programs can do that.
>Photoshop Elements allows you to change multiple photos. I suspect Photoshop may as well but not sure. Lightroom lets you adjust by 1/3 or 1 stop but doesn't appear to adjust multiple photos at once.
I'm not an expert on any of these programs but I am certain about the multiple change on Elements.
>...calibrating your monitor every 30 days? JKJ has given good advice regarding Adobe Gamma, and another good tutorial is a free download at Calibrize.com
>On the LCD the upper left corner is nearly white with a subtle detail. There are no harsh feather shadows, and the overall image is subdiued in pastel pinks. when I Downloaded it to my PC, it gets like this.
There are no shadows on the LCD where the flamingoes head is. I shot this in bright, flat, Florida daylight with the camera making the correct exposure, but it almost looks like it is a slop or so under exposed. I wonder if there is a driver incompatibility or something wrong in some software somewhere?
Steve,
It's difficult to describe an image in words, but for the picture you posted I think your description above pretty much matches what I see on my monitor, the subtle detail and pastels and all.
Try this: go to another computer and view the picture you posted and see if it looks the same as what you see. Look at the two computers side-by-side if possible - are they the same?
If not, and the brightness/contrast controls of your monitor cannot adjust it properly (using a calibration aid), then one of two things comes to mind: Look in your display properties (r-click on desktop, properties, settings, advanced) and see what adjustment options are provided by your driver. Some have only a place to assign a profile (which you will create using the calibration process mentioned earlier) and some give you manual control.
If none of this works, try plugging in another monitor - if something changed recently it is possible the monitor/screen hardware has a problem. (This will do NO good if the settings in the computer are the issue.) Far less likely but I suppose possible is the display driver has developed a problem and should be updated.
What you describe sounds a lot like what you would get if running with the incorrect display gamma (which the calibration should fix) but it could be anything. These things sure are hard to see long distance!
>First, (remembering the medical and electrical posting issues a while back), I have a LOT of experience in film-based photography (and optics), but I'm about as much of a hack at digital photography as a chimp leaving the camera store.
So, I'll pose this as a question -- mostly 'cuz I'd like to know, too: could your original exposure have been underexposed a stop or two?
With B/W film -- or worse, color slide film -- shooting white objects or very light colored objects, especially in bright sunlight, can fool the camera's built-in metering system. In the estar & silver-based world, the camera suggests, or selects, an exposure relevant to an 18% gray card. Since flamingos and snow are lighter in color, they need to be "over-exposed" to be properly exposed, to avoid coming out gray.
For those of you who really know the digital domain, could that be the issue here, too?
>I think that the issue is that the calibration on the LCD is different than the monitor I looked at it on. All three (two monitors and the camera) are very different, and it never occurred to me that it could be that simple.
As far as shooting the original image, I did my very best to meter off of something that I expected to be about 18% grey to avoid blowing out the highlights in the "white" section. As a long time semi-avid photographer, I am familiar with the intricacies of B&W and printing- and I switched to digital a few years ago because I got lazy...
>In college I really wanted a monorail 5 x 7 view camera, and considered one sold by Minor White's biz -- was it called "Zone-6" ? Never got it, but did get to play with a huge Durst 8 x 10 enlarger in the electron microscope lab -- glad I didn't have to pay for that puppy!
Anyway like Steve, all I shoot these days is digital so I ought to join the 20th century!
>Great! Glad you didn't adjust all those pictures yet.
BTW, making everything consistent is one of the biggest headaches in a graphics shop like I used to be associated with. Some large shops have a single person who calibrates everything including the printers. MOST shops ignore all this since it is a lot of work and few even understand how, and leave every man to fend for himself. Some people just make everything look right on their own uncalibrated monitors then learn by trial and error what adjustments need to be made for a quality print. The problem always came when work got passed from person to person, especially mac/pc (which used different monitor gammas). Fortunately, I worked by myself offsite and only had to worry about my own calibration. Even that was a big pain - I much prefer feeding goats and driving the tractor.
>I bought it on Ebay and was going to shoot large scale chromes (12"x20") until i realized the costs to buy the film and processing. Never made the camera...
