Deep "U" Flute help
mjonesrdg
>I have a 3/8" deep U fluted bowl gouge that has been my nemesis for a couple of years. Questions: (1) when is the deep flute the gouge of choice? and (2) What angle and bevel angle is considered optimal?
Thanks,
Deep "U" Flute help
mjonesrdg
Thanks,
Re: Deep "U" Flute help
Tery Scott
>My preference is one sharpened at 35 degrees and one at 55 degrees this applies to swept back wings as well
These two grinds allow you to rub the bevel anywhere
Jorge Casta�eda
>The U profile works best in the inside of the bowl according to some, I have both the V and U and I am comfortable with both, for the inside I prefer a rather blunt angle.
Brad Vietje
>Where and when to use it is personal choice, and may reflect how you learn to turn. If your mentor, or favorite turner on video uses it in a particular way, you might, also.
There are many ways to use bowl gouges, especially when different grinds are thrown in the mix.
I use a deep-fluted bowl gouge quite a lot. I usually rough turn to round with a bowl gouge instead of a spindle roughing gouge whenever there is bark involved, or when messing with rougher chain-saw cut chunks. By taking smaller bites, I can control the size of things that come flying off these irregular shapes, and reduce that danger somewhat.
Where they are used is also determined somewhat by how they are ground. Let me try to re-state that: where they are useful is determined by how they are ground. Thus, with experience, you'll be able to determine where it would be the best tool to use, and grind it accordingly.
I have one ground almost straight-across (45 deg.), one with an Ellsworth grind (65 deg.), one more like Michael O'Donnell recommends (45 deg. "Irish" grind, but that's a "V" flute), and one with a flat bevel at about 65 degrees that I sometimes round over to a convex bevel which is great for the insides of a bowl. Generally, steeper, shorter bevels allow you to keep the bevel rubbing when working in deeper bowls, and longer bevels (more "pointy") are used for shallower forms and for smaller details, etc...
SO, with experience, what you want to do with the tool should determine it's grind, and not the other way around -- don't let the tool limit what you do. Any tool can be reshaped to meet your need, and there's nothing sacred or magical about the way it came from the factory -- you can and should change it if you need to. If you don't feel confident making those decisions yet, I'd suggest working with a more experienced mentor, and using the tools the way they do.
Safe spinning,
Brad Vietje
Newbury, VT
Skip Beardsley------WebKitFormBoundarylsHY4+4w161B
>Suggest the Oneway site and their sharpening video which I think explains the process pretty well. Next best thing is to try to understand what is happening when you cut a bowl, either inside or outside. If you start with keeping the bevel rubbing all the time and watch the cut in slow motion you may get a better appreciation of why there are various grinds. Usually the grind changes when the turner gets into a situation where the bevel is not able to rub when making a particular cut, thus the change of the grind.
If you don't have one already I strongly recommend the Wolverine jig by Oneway. It will take away lots of the anxiety about sharping and reproducing proper angles easily.
Happy turning
