Wax on turning squares
>When I process my own green local wood, I wax the end grain (anchorseal) and often 1/2" or so up the sides. This seems to work well.
When I buy exotics, they usually look like they have been dipped in hot paraffin. Does anyone else scrape the thick coat of wax from the sides of spindle squares (i.e., 1"x1", 2"x2", etc)? I often have this wood around for years before using it so seems to me this will help them dry by the time I use it. I haven't seen any degrade. Does anyone else do this?
The wax is thick so I usually use a wide wood chisel followed by a cabinet scraper and perhaps a wire brush.
Comments on the method or wisdom?
Re: Wax on turning squares
Re: Wax on turning squares *LINK*
>John I asked Pete of Bigmonklumber how wood that is sold covered in wax should be treated (because he does that) He said that anything covered completely with wax should be treated as green because you simply don't know. He does that because it keeps the wood in the best condition for the customer.
I asked if it would be a good idea to scrape the wax off the sides of spindle blanks if you wanted to dry the wood. He said that should work but there is always the possibility it could start to check so watch it often.
That's what I've been doing and in fact I've been cutting any wood in my lot that starts to check into spindle turning blanks. I coat only the ends and have had really good luck.
http://www.bigmonklumber.com/
Joe Herrmann
>Dale Nish addressed that question in Issue #25 of Woodturning Design magazine. Go to this link and scroll down to the 3rd question: http://www.woodturningdesign.com/askdale/25/.
Joe
>Thanks, good to know he does the same thing.
