Just tipped my lathe over..careful
Jake
>All,
I just tipped my 20" General lathe over....luckily away from me. It proceeded to imprint some decorative grooves into my garage door on the way down. Also broke the casting on the cover as is smacked the floor with a resounding CLANG. I was able to right it and it appears to be the only damage.
I was lifting it to put a mobile base on...trying to make it safer when I need to roll it around my shop.
Just posting a reminder to think very hard with moving and lifting these heavy objects. I am home alone and if it had fallen on me could have been a much different story.
Yes, if I had a lift/cherry picker it would have probably not happened. I was using a lever to lift it incrementally up and blocking it with 2x material. Looking back I had the tailstock end up on a cart and it slid out taking the whole thing down with it. I had done this many times before to put the small carts under it. Just did things out of order this time.
Just a quick reminder to be careful. Complacency can quickly turn into danger.
Jake
