power honing
power honing
power honing
eliot d------WebKitFormBoundaryAo1Kz+awUUYH8ShA---
>I power hone with a hard felt wheel. It certainly polishes the metal, but I wonder if I'm not rounding over the edge because sometimes the tool seems not to cut as well after honing. Anyone experience this sort of problem?
Re: power honing
Re: power honing
>I've had the same problem. I learned this with carving tools. You have to approach it like you do the grinding wheel. You buff up to the edge but not beyond. I lay the bevel on the strop wheel and then rotate the tool until I just see the abrasive start to build up on the tip. Then I hold it there and move it back and forth. The strop should be rotating away from the edge of course.
Re: power honing
Rather than felt,
Keith Newton----Little Rock, Arkansas
>I use a wheel made from MDF. After shaping the edge to an elliptical shape to fit inside of gouges, I held a coarse grit paper to it to give it texture to hold the compound better.
Works great. the same disk has served for ~25 years.
CAUTION: You have to work from the back side, with the rotation away from the edge to keep from snagging.
As suggested above. Set the heel of the bevel down first, then you will feel the bevel, then come on up another degree or two, with a light touch for just a few seconds while traversing along the wide sweep of the ellipse.
