Epoxy Hazards
David Belser
>I've been working with combining epoxy with my turnings. I'm using System 3 general purpose resin but my question about hazards applies to all epoxy systems. I got the "epoxy book" from System 3 and would strongly recommend it to anyone who wants to experiment with epoxy. The book has a good safety section that basically says repeated skin exposure will eventually lead to an allergic reaction that will make it impossible for one to work with epoxy. So I have been extremely careful to avoid skin contact always using gloves and disposable mix pots (plastic cups and plates, lots of paper towels)
The book states that because epoxy resins and hardener have high vapor pressures (don't evaporate much) the fumes are not a problem.
Very recently someone told me of a turner who lost there sense of smell from using epoxy! So I went and pulled up the MDS for the epoxies I'm using and found only a barely useful:
"Respiratory Protection: Normally none is required when adequate ventilation is provided."
I'm using what I would consider to be very small quantities at a time (~2 oz - half of a small cup) compared to what the boat builders that use this stuff must mix up and I'm doing this in a large room 20x25'.
I'm particularly interested because I'm exploring a process that requires working over/close to the epoxy as it gels for 2+ hours. I've had no issues doing this yet, but it may end up being a process that I do in front of an open window with a fan (unfortunately it is currently about 6 degrees outside!)
So my questions:
Has anybody had a problem with exposure (breathing) to epoxy fumes?
How much risk is there with this?
Have you lost your sense of smell permanently?
How much ventilation do you use when working epoxy?
- Dave
