WoodRiver Turning Tools?
>I want to modify a flat scraper in terms of the profile and bevel. Naturally I don't want to use the one that I have currently - unless I can buy another.
I'd like a reasonably long handle and a reasonably long steel. Anyone looked at the WoodRiver tools or tried them? Being out in the sticks, I don't go down to the city but so often.
Re: WoodRiver Turning Tools?
Ron Lynch
>Haven't used a WoodRiver scraper, but I have a few of their gouges and they have long handles and reasonably long steel. Seem to be good quality tools.
David Belser
>I use them all the time for just this purpose. Woodcraft caries them and they are relatively cheap ( 1/2x 1/4" round nose).
I modify the shape and have even chopped a handle so that I could scrape an exact radius (using the tail stock as the center anchor point). Because they are inexpensive I have no qualms about modifying them.
The other option is to by O2 (oil hardening) steel from MSC or Enco in whatever dimension you need and make your own shapes and lengths. You have to do the hardening correctly - you need a hot torch propane won't work - and make your own handles. This is probably cheaper still but more work.
I'm placing an MSC order myself, as soon as I have money again.
- Dave
How do you cut the tang?
>I've found the steel ($36 for an 18" piece). I would need to cut a tang to fit it into a handle. I would like to have a scraper that is 1" x 3/8" thick. I know I can get a 3/8" x 3/8" piece into a handle.
I have horrible images of me trying to cut 5/16" pieces off of each side with a hacksaw. I do have some blacksmith friends who might help.
Re: How do you cut the tang?
>I use a 3 1/2" angle grinder with a cut off wheel. It's easy to cut this stuff with that and a steady hand. If your nervous with that just get one of the abrasive wheels. It will take longer but you can remove quite a bit of metal with them.
David Belser
>Like John says, it's pretty easy to work with *BEFORE* you harden it. Hacksaw, grinder, cutoff wheel etc.
Thanks.  I will have to try it.
>Fortunately my friend David S. is a blacksmith/engineer who a) owes me some favors and b) likes to heat treat metals.
Re: Thanks.  I will have to try it.
David Belser
>The other point (which your friend will know) is that you don't harden the full tool shank, just the cutting end.
The guy who showed me how to do oil hardening uses a magnet. You heat the end of the shank until a magnet won't stick to it and then swirl it around in a can of oil. The crystal structure changes when it gets hot enough - the magnet not sticking tell you when you have reached this point. You swirl it in the oil to cool it quickly, you don't want a layer of evaporated oil around the hot metal acting as insulation.
You can also watch the color change, but the magnet gives you a yes/no result rather than judging color.
Have fun.
doug williams
>I use a .045 cut off wheel in my right angle grinder to cut drill rod etc. for jigs and things of thick metal. It may take a little while but a lot better than a hack saw or bench grinder. Clamp in a vise and grind away, suggest safety glasses. The cut off wheels can be found almost any where and really make a job like this easy. Doug in ohio
You don't have to cut a tang!
Jorge Casta�eda
>Just make a handle around the flat bar.
Easier and much stronger.
Re: You don't have to cut a tang!
David Belser
>George, he is talking about a 1" wide scraper - that would be a pretty big handle by the time you allowed for enough wood to go around it!
