Re:Setup and exposure are excellent,,,...
JamieDonaldson
>... but the camera may have been on autofocus and targeted the front of the bowl, diminishing the DOF available at f 16. A point of critical focus 1/3rd behind the front(and 2/3rds in front of the backmost point)yields max. DOF, and that requires manual focus override capability. By using the gray background you have reduced most of the need to manually adjust exposure compensation caused by high reflectance of a white background, but some folks sputter at the cost of fragile roll paper backgrounds! The paper needed to have more uniform sweep in the back to eliminate the visable transition area shadows from horizontal to vertical. The shadows on the R side of the bowl could be filled more with adjustments to your bounce board angles. The crop is a bit loose, but ideal for master image files that might have to be cropped differently in the future, such as square for jury submissions like Zapp. All in all it looks pretty darn good!
