Saving Bowls with Coffee/Epoxy etc.
Tom Minehan
>While learning to turn bowls I used wood that had defects like cracks, loose knots, punky spots, etc. I kept some of these bowls figuring I could use them for learning how to perhaps "save" a keeper bowl. I'm ready to learn and have the following question.
"When do you apply the mixture of whatever you are using to fill a crack or other defect and how is it finished"? "Can it be applied at the rough bowl stage and finished with a gouge or must it be applied at the final stage and finished with sandpaper"?
I realize it may depend on what the mixture is but for starters I plan on trying coffee grounds and epoxy.
THANKS for your help and any peripheral help is appreciated!
Re: Saving Bowls with Coffee/Epoxy etc.
Brad Vietje
Brad Vietje
>Tom,
Yes, you can apply these secret save techniques at almost any stage. I usually use the coffee ground method to repair broken bark edges, or to fill in a void in a bark inclusion.
I've never used coffee grounds and epoxy, buy I have packed in used (slightly damp) coffee grounds, then flooded with water-thin CA. Since CA is catalyzed by water, you want the grounds mostly dry, but a little moisture is good -- no accelerator needed. Epoxies might get cloudy with any moisture present, and I have to ask those who've used it how well it works with green wood -- CA will be fine, but really wet wood can cause foaming or a sort of white color to the repair.
Anything that creates a hard, plastic, artificial patch in the piece will not cut, sand or absorb finish the same as the wood around it. Usually light cuts with gouge or scrapers will work just fine. For sanding, we need to remember that hardened CA is usually harder than the wood, so it may need a little extra attention so it doesn't "stand proud" of the softer wood.
Thin CA can also bleed into the edges of the defect, which can darken those areas, and radically change their absorption of dyes and finishes. A little experimentation with pieces you don't care much about will be very instructive.
Safe spinning,
Brad Vietje
Newbury, VT
Wally Dickerman in Arizona
>Apply some lacquer or even finishing oil around the defect before using CA...Keeps the CA from soaking into the wood and discoloring it.
Wally
Steve Kubien
Steve Kubien
>My typical "save" procedure involves sanding dust and epoxy. I mix the epoxy and add the dust to it to create a uniform filler. I apply it so it stands proud and over the edges then I can cut with a gouge quite nicely.
I should point out that I do this once I am near final size on the piece and still have enough wood to cut with a gouge. Once you've got it REALLY close (like, scary close!) I will do it again if there are any air bubbles or other voids that need to be filled. Sand and finish as per normal. Your finish either sticks to this new, plastic surface or it doesn't. No worries because it is plastic!
fgvanatta
>For inlays, mainly turquoise:
� Finish turning the surface, sand to 220/240, coat w/sanding sealer
� Inlay the stone particles slightly proud of the surface and flood w/thin CA glue
� After the glue dries (I often use accelerator so that it dries more or less instantly) remove the excess glue down even with the wood using a scraper. Make sure all the glue is scraped from the surrounding surfaces.
� Resand to 220/240 and proceed as you normally would.
DaveL
>Where do you get your stone?Thanks in advance.
Dave
fgvanatta
>I buy either small nuggets or reconstituted cabochons, usually at flea markets, then pulverize them in a small steel cup with the end of a socket wrench. You can make the ground pieces as large or small as necessary to fit your project.
The reconstituted pieces work better because the nuggets are apt to have spots of quartz in them which you must either pick out of the crushed mineral or suffer some white spots in your finished inlay.
If you would like some "veining" in the finished product just add a small amount of ebony dust.
