O.T. Photo Help please
Paul Zerjay
>I have an application to show that is requesting jpeg images to be 300 PPI. My saved images are 96 DPI. Am I in the ballpark?
Re: O.T. Photo Help please
Ron Sardo
>Sorry Paul
300 ppi is for print, 96 ppi is not even one third the way there.
The photo(s) will look fuzzy in the publication
So you are saying...
Paul Zerjay
>That PPI (pixels per inch) and DPI (dots per inch) are the same thing?
karl jr
karl jr
>Dots per inch and pixels per inch are analagous. If your images are 96 DPI, your resolution is way below their limit. In fact, they are much lower resolution than necessary. If your images are used at 300 DPI, I suspect that they will have the jaggies; curves will look like steps.
>Paul I am definitely not an expert at this stuff, I shoot photos but I'm still trying to understand the digital stuff. You are only giving us part of the equation. What size are your photos, not just the DPI. For example my camera's standard If I shoot JPG comes out as 72 DPI but the image size in pixels is huge, something like 21,000x28,000. If I change it to 300 dpi it reduces the image size to a much smaller size. Your camera might be saving them at 96 dpi but the image might be pretty large. That would mean you could change it to 300 and get buy. Trust me when I say I barely know what I'm talking about here and had to pull numbers out of my head. What I'm saying is all may not be lost if you were shooting at the largest file size your camera offers. I jut might save them at 96DPI but they still might be large enough to use whe converted to 300 dpi. I usually send 5x7" dpi's at 300 dpi to publishers and they work just fine.
Re:PPI and DPI are similar but not.....
JamieDonaldson
>.....the same by any means. Think of camera output to CPU memory in terms of PPI, and CPU to print output as DPI, the way printer heads operate. And John, your JPG files from camera should be set up to at least 300 PPI for max resolution. Downloading lower resolution original image files really limits the ability to scale images for larger output later. I believe I recall that you have Nikons, and they should/could be set to output both RAW+JPG image files for greatest post capture flexibility.
Don Evans
>What is the application that is asking this? We may or may not be familiar with it.
PPI and DPI are not the same thing. My understand is that a picture sent over the internet can only be 72 dpi but that doesn't affect the physical size of the picture.
Example: a 600 Ppi high x 600 Ppi wide picture is 8" x 8".
When it is resized to 300 x 300 ppi it is reduces to 4x4.
That help?
You application should have a resize probably under EDIT at the top left that allows you to change the picture size, usually you can do that either by changing the ppi or the inches size. There should be a box to check "to keep the aspect ratio" normally you want to do that so you eliminate accidentally distorting the image or chopping it in one direction. If that is check, you only have to change one setting either height or width and the other will change with it.
Don
Paul Zerjay
>Years ago I started using irfanview. I have never come across this PPI vs DPI before. Irfanview only uses DPI for resolution. Most of the juried shows I do require images to be a certain number of pixels square, and no larger in file size than 2MB. I dunno if it's just been dumb luck in the past, but I have a pretty good track record for getting into shows.
so  much confusion
Paul,
Just what application is asking for 300 dpi and why? If you describe this, you may actually get some useful information.
I worked in computer graphics for many years and generated images for publication in magazines, newspapers, huge displays, and network televison. In the professional graphics field, we dealt with this confusion all the time. When I was the moderator on a 3D graphics forum, this was discussed often - I once complied a FAQ which addressed this in great detail and we used it repeatedly. Wish I still had it around.
We never knew whether to laugh or cry when someone (it was usually magizine people) insisted on a 300 DPI image. They usually required this without specifying the image dimensions, indicating immediately they had no clue what they were talking about. We finally figured that 300 DPI was a mantra that graphic artists and editors were taught to repeat in school to give them a zen feeling that they were on the top of their field. Or like gamma or color space, it was something that no one ever took the time to understand so they just stuck with what everyone else was saying.
The bottom like: PPI/DPI is MEANINGLESS to images used for viewing, whether JPG or other. It only applies when outputting to a device that measures the image in inches (the I in the acronyms). The only thing that matters otherwise: the pixel dimensions, the number of pixels horizontally and vertically. Note that DPI/PPI numbers are RATIOS, not dimensions or quantities. The PPI and DPI numbers are meaningless on a screen unless you know the screen size AND screen resolution. The numbers are useful in the printing business, but even then they are blurred by things like inkjet and dye sublimation printers. The D in DPI is a printed dot, but without knowing the print technology it tells you nothing. Some printers will spray multiple (e.g. 4 or 9 or 16) tiny dots of discrete colors are sprayed or diffused for each pixel in a digital image. You can set this yourself on some inkjet printers when you specify the dot resolution, but most printer drivers have seemd to dumb this down and only let you choose a quality level (High, Draft, etc). Some types of printers will print one dot per image pixel. However, even these have internal hardware which will process the image to try to get the best picture at a given size.
DPI/PPI are in fact useful when scanning so you can get the required detail.
An aside: the practical requirement for DPI in a printed image depends primarily on viewing distance. A magazine in your face might use a high resolution, I've printed pictures viewed 4-6 ft away at 40 dpi, billboards along the road perhaps need 10 dpi.
Some computer applications, such as presentation programs will use the resolution info but some simply resize images to try to hold your hand for you. (Some info in the link below) Digital cameras will sometimes set the resolution to some value for you. Some image processing applications will read this and some will set their own, or set a default if none is set in the file. You can look at File Info in Photoshop to see what info is embedded in the file (EXIF data fields). Some software applications ignore DPI completely.
Think of this: a 3000 pixel image at 300 dots/pixels per inch will come out 10 inches across if printed 1:1. A 300 pixel image at 300 dots/pixels per inch will be printed 1" across. Both are 300 DPI. One may be useful, the other not. When someone asked for 300 dpi, be sure to ask the target image size in inches. If they don't know, just send them anything you like and tell them it's 300 dpi. If you are using a software application that is in fact sizing images based on DPI, you may have to do the math to give it what it wants to get back what you need.
Try this: load up an image in Photoshop. Turn off Resample Image. You can set the resolution to anything you want. The image doesn't change (the number of pixels doesn't change). Set resolution to 300 if your application insists and save the file.
For more than you ever wanted to know about this, search Google for JPG DPI. The very first one that came up was this:
http://www.pptfaq.com/FAQ00075.htm
You may want to read this and others. Or describe better what you need.
Re: so  much confusion
Paul Zerjay
>Usually I use an online jurying service. But this is a paper application that must be sent in the mail. They are asking for a cd with 4 images of work. The images must be 300PPI. I seem to remember sweating over this last year too. I didn't know what to do, so I simply copied some images that I use for the online service onto a cd and sent it in. I got accepted, and won a pretty nice award. I'm just gonna do the same as last year.
John, I think you may have a point about them not knowing what they are talking about. They ask for a release so they can publish pictures of your work in their promotional flyers. I am sure the printers are asking for this resolution. The art fair themselves will jury through computer monitors.
Re:Paul- are you using Zapplication?
JamieDonaldson
Just FYI
Don Evans
>When you used the word "APPLICATION" I and I'm betting lots of others took that to mean a particular computer program was "asking for".
Don
Sorry, woodturner here...
Paul Zerjay
>Not a computer geek.
Re: Sorry, woodturner here...
Don Evans
>No applogy necessary sir, I was trying to justify MY somewhat in accurate answer due to my misunderstanding...
I've worked with computer big and small since 1970's and fortunately I have forgotten as much as I can since retiring. I just want to use them now and let the younger folks become the experts on the new stuff!
Don
