>I found an old can of Anchor Seal in the shop this morning, maybe 5-6 years old. I had a piece of green Walnut that needed sealing so I used it. That was 6-7 hours ago. I just checked it and the stuff doesn't seem to be drying as fast as I'm used to. Does anyone know if there is an expiration on this product? It's about 72 degrees in the shop with a very low humidity level.
>If you've stored it indoors in a heated space, it should be fine. You can shake and stir it, and see if it has settled at all, but it should be fine.
For cold temps, they make freeze-protected Anchorseal, too. If the regular stuff freezes, it looks more like lumpy cottage cheese, or a solid block of styrofoam, and really isn't usable (DAMHIKT).
>I have had good luck with previously frozen Anchorseal. Put the entire container into a bath of very hot water. Shake several times, while removing and putting it back in the water. Good as new.
The Anchorseal product should be OK to use, however I would take the can to a paint store and ask them to put it on a mixer for a few minutes to thoroughly agitate the can in an attempt to re-emulsify the various components which may have settled-out in the can. BTW - "winterized" Anchorseal has a certain amount of denatured alcohol added to lower the freezing point of the mixture (I think maybe 10%??). It is supplied from the manufacturer (UC Coatings) in winterized form when ordering it; the cost is trivial for the extra freezing protection.
>I bought a 55 gal drum once. If in doubt, call UC coatings and talk to the rep. He told me that if it separated due to freezing or sitting too long, just agitate. (shake, rattle, roll, or use a paint stirrer) The stuff is just wax, emulsifier, and I think a wetting agent. Even the antifreeze version will separate under some conditions. Now if it coagulated into unmixable chunks of wax I'd think some serious blending perhaps with heat would be needed. Look up how to make a wax emulsion and you'll read that is how they make it in the first place. I've had jugs here for about five years with no obvious degrade.
