Re: Display rack suggestions
Mike Foster
>Hi Ed,
I looked through my photos and found an angled shot of the shelves. Gives you a better idea of the construction. It may have been a little overkill, but I thought that I am only doing this once so I'll do it well. I can't remember, but believe the tilt of the shelves was 5 degrees on both sides. I did double through tenons instead of one large ones. I thought it would look better and help to keep the unit more rigid. The mortises were made at the same angle as the tilt. I did these the old fashioned way. Drilled holes at the 5 degrees, then cleaned it up with chisels. I don't have a mortiser, but that would sure make it easier. The mortises in the shelves were laid out after the sides and shelves were made and fit together. I just marked the top of each tenon the same distance from the side on the top of the shelve so that the wedges would all fit the same. The mortises in the shelves are not angled, as the sides are already tilted in, so that when the wedge with a 5 deg taper is inserted , it fits flush to the side and the mortise. A little tap on each wedge after the whole is assembled and the unit is solid. I took care with all the joinery to make it fit well so that the whole is solid when assembled with no metal fasteners and no glue.
I designed these myself after looking at a bunch of plans and not really liking any. I probably borrowed ideas from a few and put them together to come up with this design. I don't have a lot of desire to do outdoor shows, so did not design the shelving around that. I would probably design some sort of add on to make the stance wider front to back for that situation. These boards are 11" wide, so the unit does not have great stability in that direction.
