Union Graduate Lathe
Skip Beardsley------WebKitFormBoundarylsHY4+4w161B
>Greeting all.
Once again I come to this site for assistance and information. There is a Union Graduate lathe being sold as part of an estate here in our area. I am not really looking for another lathe and have no idea of the value of such a lathe. It looks to be rather stout and I believe it is made, or was made, in the UK. Anyone out there have any information?
Skip
Re: Union Graduate Lathe
Mac Ray
>Skip, They are British,good quality,old technology.....can be retrofitted with a newer variable speed motor if desired.....they are heavy,well built and a bit hard to find......if one ever comes my way,I'll have it in a heartbeat..........sort of an early version of what the VB is now........
John Peck
>You can find detailed info about the Union Graduate lathe here - http://www.lathes.co.uk/harrisonwood/index.html
Rob Wallace
Re: Union Graduate Lathe *LINK*
Rob Wallace
>Skip:
The UG lathe can't be too shabby if Richard Raffan has been using one for years and years. If it were available here at an estate sale, I would be looking to buy it if offered at a reasonable price. I understand they are built like a tank, and very solid. As mentioned above, changing out the motor with a recent one should bring this unit more into line with "modern" lathes as to drive control and general function (reverse, infinite speed adjustment w/good torque, etc.). I suppose my only concern would be the sizing of the spindle threads, spindle and quill taper styles, and banjo/toolrest size to be sure currently available aftermarket accessories (chucks, drive centers, live centers) could be procured for the machine without requiring special adapters be made for it (I don't know this machine's spindle threading - I would check into this specification).
Considering the age of the machine, condition, need for upgrade, etc., I would definitely make a fair offer on it, and hope that I could swing the deal.
Good luck!
Rob Wallace
(... and don't hurt your back getting it home!)
PS: For educational purposes, I found the image at the URL below for those that have never seen one of thee lathes...
Image of Union Graduate Lathe
Link fixed for Union Grad lathe
Don Evans
>Your link is bad, it has a double http// in it.
Re: Link fixed for Union Grad lathe
Don Evans
>Interesting, I made above message with the corrected link but had to go back in and edit it. But link will NOT show? Trying again to get link to work
Don
Re: Link fixed for Union Grad lathe *LINK*
Don Evans
>One more time
Union Grad link
Rob Wallace
Rob Wallace
>Thanks Don!
I tried several times to get back to the edit mode to fix this in my original post, but could not find an "edit" radio button even though I am logged-in and recognized. I hope the attached link works better. As I post it, it seems to have only one 'http'.
Sorry for the bad link!
Rob
Correct link for Union Graduate lathe image
Don Evans
>I found a problem when trying to correct this as you see it took 3 tries to get it to work.
I sent a "trouble report" to those in the know of what happened.
Posting links
>Hi guys,
The URL textbox in our forum software already has the "http://" filled in, so if you copy an entire URL from the address line of your browser and paste it *after* the existing "Http://", it will be a duplication and the link won't work. The trick is to highlight the :http:" in the URL textbox before pasting your new one in. That way, your link overwrites the existing "http://."
In the old forum, I found out how to get into the depths of the scripts where this "feature" is programmed and eliminate the "http://." Eventually, I'll get to it here, too, but we have a lot of other work to do first. I'll put it on the list.
Also, Don, regarding your attempted fix, I'm not sure what you did, but there was no link in the URL box of either of your first two messages. I'm not sure what happened, but I can mention it to the author of the software.
Russ Fairfield
>Grab it. It is a wonderful lathe if all the parts are there and the price is right. The worst that can happen is that you will have to replace the bearings, and the variable speed motor is always an option.
Re: Posting links
Don Evans
>Ellis, I emailed you again. But for the forum I'll say that I did it the way you state above, I erased the http:// that was in the box and pasted the full link I had copied and did it two times that way and it didn't work. The link box was propogated with a good link when I hit the post button but the links disappeared.
I then got it to work by NOT erasing the http:// in the box but instead erased the extra one that was in the link copy after I pasted it in the box.
It appears it's a matter of WHICH http:// you erase that matters at this juncture.
I'm gonna try it again to see what happens by highlighting as you say as I erased it in messages that didn't work with the delete key instead of marking for overwrite.
If there is no link on this message then the mark and overwrite did NOT work.
Don
Re: Posting links
Don Evans
>Doesn't work Ellis I'm testing one more thing with this one.
Re: Posting links *LINK*
Don Evans
>OK marking http:// so the pasted URL overwrites it does NOT work.
Here is test where paste only THEN erase the second inline http:// that is in the pasted link and I'm sure it will work, as it did before.
If this works it proves that it matters WHICH http:// you erase after pasting, you have to erase the second one in the line.
Don
http://www.woodworkforums.com/attachments/f221/109538d1246443651-harrison-union-graduate-lathe-009-copy.jpg
Don Evans
>I agree with Russ but if you are new to turning understand that this lathe is made for bowl turning. Or smaller stuff. What it isn't very good for is Hollow forms and doing them with a bar system like the Lyle Jamieson due to short bed. If I didn't have a big lathe already I would still get it and make necessary modification even bed extension as I just like the older heavy iron. They just don't make 'em like that anymore.
As I have a ONeway 2436 I don't need it however. You'd have to way the price of what they want for it, the mod's added to it and compare that to Oneway or Robust maybe a Stubby.
Don
Rob Wallace
EXACTLY Don!!
Rob Wallace
>I had the exact same experience Don! - You can't over-write the original "http://" with a copy and paste of the desired URL; this doesn't work! And if you do add a second http, you have to remove that one and leave the original 'http//:' in place. Doing so allows the link to appear in the post - anything else is rejected.
Growing/learning pains, but a fairly easy solution...
Rob
