Hollow Form
Mike Foster
>New hollow form. Just finished sanding this tonight. Amazing how size does not seem to matter in how much time is invested into some pieces. Hollow form maple, 2 1/8"d x 2 1/2"h.
Hollow Form
Mike Foster
Re: Hollow Form
>Good job carving. The details look crisp.
Re: Hollow Form
Cyril Griesbach
>It's an interesting design, Mike, and as John says the details are nice and crisp.
Re: Hollow Form
karl jr
>Looks nice. What's the opening size? Looks to be about 3/8 - 1/2 inch. How about the wall thickness? How much material did you leave to carve away? I certainly agree that size doesn't necessarily correlate with to time.
Re: Hollow Form
Mike Foster
>Thanks John and Cyril. Karl the opening is 3/8" now, probably less before carving. The walls are thin, but I didn't measure, perhaps started at about a thick 1/16-1/8". If you look inside the vessel, you can see through all the lines at the depths of the grooves. I didn't anticipate carving as deep relief as it came out and I got a little carried away. I was using a V gouge to sharpen the depths of the grooves and actually perforated the wall in one small place. I repaired it with a little super glue and considered using flat black paint to highlight the carving and hide the defect, but went with a oil instead.
