Distraught
Distraught
Distraught
Paul Zerjay
>Ever have a project that just goes south on you? I love it when a project comes together, but when it goes bad, it's just a bummer. I've got a large Ambrosia Maple HF that ovaled so bad I can't true it up. Besides that, I used a faceplate and the screw holes cannot be turned away. I saw a beautiful ceramic vase last summer at an art show, and I wanted to replicate the form. I spent time and money and now I'm left with what will only look like a save. I should know better. I've not had real good luck this past week.
Re: Distraught
Re: Distraught
>Carve it. I have a Wysteria bowl that warped so bad after roughing that you can't put it back on the lathe. Well you could but by the time you trued up the sides 2 of them would be gone. One of these days I'm just going to thin them out and leave them oval.
Re: Distraught
That's why "fishin' is fishin ", ya know?
mjonesrdg
Re: Distraught
Re: Distraught
>I understand. When something goes so far wrong it is unrecoverable, I have to grieve over it for a while. My son, OTOH, just says "I have to get another piece of wood" and goes on.
After I grieve my second reaction it to go to extraordinary lengths to save the project. I had that happen with a bowl recently. The saga is too long to repeat, but it was a terrible ordeal. If I had had another piece of wood, I would have trashed it.
Can you turn a little away on the outside and on the inside to make the piece lighter if not round and then sand it into submission or carve it as John suggests?
Re: Distraught
Richard Allen
Re: Distraught
Richard Allen
>You can likely make the object round again by introducing moisture back into the wood. Once the wood is full of moisture it will regain the round shape you had it in when you set it aside to dry.
You can now apply presure to the piece so that as the wood drys the oval shape will not be as large. That's right put clamps on it to help the drying vase mantain a more round shape. You will have to readjust the clamps each day.
The cowboy hats are "forced" into a "head" shape while drying.
Wet bowls in the bowl factory are stored for drying in such a way that the oval is limited.
This should work. If it doesn't then you are out the time for rehydrating the vase and the time and effort to dry the vase a second time.
Re: Distraught
Re: Distraught
JamieDonaldson
>You might have some luck with re-hydration, but I doubt it will move much back to its original roundness. That's why hollowing is best accomplished in a single session process, and I let much of the water dry out before I start turning. If it's wet enough to spit on me while turning, then it's too wet to sand and finish.
Re: Distraught
Re: Distraught
Dinyar Chavda
>Paul:
Does it have to be true? Can you accentuate the out-of-round aspect so that it looks deliberate. It may not be what you wanted to achieve initially, but that's the nature of working with wood.
I find that when something like this happens, I will put the piece away so that I can still see it, and snarl at it, and sometimes, alternatives will come to mind. Another way of playing with it is to take pictures of it, and print them out (usually, I prefer black and white), and see what can be achieved on paper.
Good luck!
Re: Distraught
Re: Distraught
D. Hansen
>could you possibly put a long piece of wood on the drive center that would reach to the bottom of the HF then bring up the tailstock (make a jam chuck in effect) to turn away the faceplate holes?
Re: Distraught
Keith Tompkins
Re: Distraught
Keith Tompkins
>HI Paul, on my linenfold pieces, I take advantage of the wood moving. When a piece is dry and out of round, I turn it again as true as I can until two sides are very thin, and two are heavy....I carve away the heavy walls into linenfold. Hope this helps.
Re: Distraught
Re: Distraught
Paul Zerjay
>Thanks for all the replies folks. I think I may have an idea that won't look too much like a save.
Re: Distraught
Compressed air
>Ever watch the other John Jordan turn a hollow form? After hollowing he forced compressed air into the open end and I was surprised to see how much water bubbled out of the pores. This was maple, I think - might not work with some woods like white oak or cocobolo.
