Pendant
Pendant
Pendant
>I wanted to play with my new pendant jig so I threw this piece of scrap on there and played with it. This is going to be fun. I can see wasting way to much time with this gadget. This is about 2" across. I keep forgetting that I make really small stuff and have to start warning people. :)
Re: Pendant
Re: Pendant
Norm Smith
>Cool stuff John. What is a pendant jig?
Norm
Re: Pendant
Re: Pendant
>This is an Aluminum jig for doing offcenter work that was posted a few weeks ago by Ed Davidson. It looked like a good project for my metal lathe/mill so I built one. I have the video links at home on my computer but you may be able find it here.
Re: Pendant
Thanks John
Norm Smith
Re: Pendant
Re: Pendant
>You can get Richard Joyner's contact info from the end of the video on Ed's web site:
pendant_1.wmv
pendant_2.wmv
If they won't play from the web site (I kept getting an error), you might copy the videos and play them directly from your computer.
Re: Pendant
Fancy ply name?
Bill Howatt
>What is the name of the purple and yellow ply he is using in the first video?
Thanks,
Bill
Re: Pendant
Re: Fancy ply name? *LINK*
Jorge Casta�eda
>Bill,
I don't know what they are using, but Rutply in Rutland, Vermont makes plywood with layers of many colors and thicknesses,
One of their brands is Diamonwood.
Look in there maybe you'll find something.
Jorge
rutply
Re: Pendant
Ed Davidson
>Bill,
It's a solid hardwood laminate called SpectraPly - there's a link to the outfit I buy from below - usually sold in large sheets measuring 36" x 12" x 2.5". If you need something smaller, drop me a line - I've got lots of the stuff.
SpectraPly
Re: Pendant
Thanks guys I've been out all evening
Re: Pendant
Re: Fancy ply name?
Galen Vetterick
>Ed
I have saved your video and you will become my turning instructor for the near future. I hope to see Richard's pendant jig show up in the mail in the next few days. Richard says the version I will get is to have additonal holes in the indexing plate to use screws rather than tape to hold on the backing block.
I was concerned when you covered the turning speed and need to have a heavy lathe but Richard says he used on the same Jet 1220 I have with no problems. We will see! I do have the PSI bottle stopper mandrel and the threads seem to be standard as I will need my chuck for the drilling.
Now I just need to follow your safety suggestions to stay out of trouble!
Thanks for providing such clear and detailed information.
Galen
Re: Pendant
Link to Richards site
Norm Smith
>I watched the videos (which are great) and tried the address but cant get there. Could you give me the link please.
Norm
Re: Pendant
Re: Link to Richards site *LINK*
Galen Vetterick
>If I did this right it is the home page to Creative Pen Design. Richards pendant fixture is NOT advertised on the site as of yet. I corresponded with him by email and that is given under Contacts on the site.
richard@creativependesign.com
Home page
Re: Pendant
Thanks for the info on Spectraply
Bill Howatt
Re: Pendant
Thanks Gaelin
Norm Smith
Re: Pendant
Re: Thanks Galen (sorry for mispelling)
Norm Smith
Re: Pendant
Re: Pendant
Galen Vetterick
>John L:
I got Richard's pendant backing plate yesterday so I had to try and do my first pendant last night. I quickly learned why Ed's video covers marking the position of the rest and banjo.
Other than years more turning experience how did you get your pendant decorative criss-cross cuts so symetric? Good eye-hand coordination?
I can do the simple "smiley face" but not the criss-cross with the indexing plate.
Would a flat bar box rest help me as it could be set at an angle to the pendant and them the skew always run parallel to the long edge. Just a matter of feeding the skew in and not so "free" as over a regular rest?
Got any other coments?
Yah, I know keep at it.
Thanks Galen
Re: Pendant
Re: Pendant
Don Evans
>Galen, in addition to marking the ways so you can line up the banjo did you catch the tip about marking the tool rest at an angle so you can place the skew back on rest at same spot and angle each time? You would also need a mark ON the banjo so you could set it at same spot front to back on the ways. Perhaps a mark showing where the banjo lines up with the gap in the ways. So that is total of 3 marks needed. That's my take on it anyway.
So mark on ways for banjo.
Mark on banjo for front to back to set banjo.
Mark at angle on tool rest.
Did I miss one?
Don
Re: Pendant
Re: Pendant
Galen Vetterick
>Don
Ed's tool rest is a healthy size so his angled line shows better. On my little Jet 1220 rest I epoxied a 1/4" drill rod on the top so you only end up with more of a dot and harder to show angle for skew. I don't have a boxes rest of flat bar but that seemed like you could mark a repeatable angle better.
John's pendant pictured looks to be real uniform for the criss cross pattern and it just looks like it's going to take more care in repeating the cuts.
Kinda stalling on cutting any more decoration as I am using some segmented scrap and burl that look fine without the extra cuts. Will get to in time.
I used masking tape on the banjo and bed as most of my markers would leave permanent stain on cast iron.
Thanks for comments.
Galen
Re: Pendant
Re: Pendant
Don Evans
>Understand now, here's an idea you can build on or improveone.
Take 2 1" square pieces of wood 1/4" - 1/2" thick. These will go on the front and back of the tool rest but will be held together with one piece of wood laying flat on the top of the 1/4" round bar, glue it to the other two pieces of wood at the angle you want, the two 1" square pieces will be canted, one on front will be further to the left than the back one. This makes a saddle that will set down on the rest. You can add a screw to the front or back in the middle of the 1" square to tighten down so it doesn't move.
Want to really get fancy, make it so the angle can be adjusted!
Just food for though.
Let me know if you come up with something better.
Don
