new segmented mirror
>I don't usually do segmented mirrors but I had one board of yellow years that was too narrow to make a mirror in the traditional fashion.
If you look closely you can see the problems that you have if your segments don't come out perfect. The yellow heart did. The purple heart was just a hair off so I glued in up in pairs until I got to 180 degrees. After gluing up the 2 half rings I sanded them perfectly flat and glue them together. What happens when you do this is it throws off the alignment so the joints don't match perfectly all the way around. If I had a design that needed to line up I would have been screwed.
The center piece is a lamination of several layers with grain oriented 90 degrees from each other. This way the center won't move. If you glue a solid piece of wood in a segmented ring you risk damage due to wood movement. I learned this the hard way.
