Pierced frogs
Mike Foster
>No, this isn't about a science project. This is my first try and test doing a pierced piece. I was really just experimenting, so did not really take a lot of time with any of the steps involved. I lightly cleaned up some fuzz with the radial bristles. I did not bother to remove burn/scorch marks inside the piercings. I used a woodburner to define some of the frogs. Then, just for fun, I tried a little coloring with prima colors. I didn't knock myself out (as apparent) with the coloring, was just seeing if coloring with markers would mix with the piercing. I also only pierced and colored what is shown in the picture, didn't bother with the other side. Probably won't finish the piece, but it gave me a real feel for what to expect.
I knew this piece was just practice as the base was far too thin in a couple of spots and the walls varied in thickness from 1/8 to 1/16. I decided to turn another piece yesterday and chucked up a chunk of maple. The shape I turned was a nice open form. All was proceeding well until I hit the rim with my light while it was spinning to use it for checking wall thickness. Instantly lost about 1 1/2" in height because the light chunked out a couple of pieces of the wall that had already been turned down to about 1/16. I went ahead and completed the form as it is just fine, albeit a little shorter.
I can't decide about the prisma colors, but may not do that again. It works ok on the outside, but getting color into the holes is next to impossible. Airbrush probably works better. I'll have to decide about the filing/sanding on the inside of the holes. Seems like way too much work, but almost needed to make a clean look. Thanks for all the advice and help. I expect I'll try a real piece in the future.
This is also a test for uploading a photo for me.
