Stuck Chuck
Stuck Chuck
Stuck Chuck
Sheldon Grand
>My Grizzly 4-jaw self-centering chuck for my wood lathe (stock number G8784, 1" 8tpi) is stuck in the fully-open position. Three of the four jaws can be "wiggled" slightly, but the fourth is completely immobile. Tapping each jaw lightly with a plastic faced mallet produced no results. Grizzly Tech Support suggested removing the circlip (retaining ring) at the back of the chuck to take it apart, but it would not come apart after doing so. The chuck is normally opened and closed using two "tommybars." I'd appreciate any suggestions anyone may have to try to get it unstuck. Thanks in advance, Shel
Re: Stuck Chuck
Re: Stuck Chuck
>There is probably a burr somewhere inside. I've had my Grizzly chuck apart and the machining was not very good. Do you have something that you can use to extend the bars so you get more leverage. The down side of this is it would be easy to bend the bars or elongate the holes in the chuck. My other thought would be to clamp one of the bars in a vice so you could push on the chuck or even put a clamp on the chuck and bar to hole this in place. Then put the other bar in and tap it pretty hard with a mallet while pushing it in.
Dumb thought but I've done it. Are you sure your pushing the tommy bars in the right direction.
Re: Stuck Chuck
Re: Stuck Chuck
Tery Scott
>Hi Sheldon
Some chucks have a screw that stops you winding out the jaws to far and you may have backed them out enough to ride up the screw Or Like John said you may just have a burr in side or the tip of the spiral may have broken off and the small piece has wedged the jaw slides in.
Id soak the jaws in turps over night then soak in Crc hold one side of the chuck in the vice and with a large pair of plumbers stylsons give it heaps.Once she starts to move try taking out the sir clip
if you still have no luck chuck it on the concrete floor l.o.l
Re: Stuck Chuck
Re: Stuck Chuck
Jorge Casta�eda
>Sheldon,
Sounds like you may have backed up too far and one or more of the slides is disengaged
Try this:
remove the jaws, and then try pushing in the suspect slide or slides and rotate the handle to close the jaws, it may take several tries but eventually it will engage again and you are back on business. It happened to me once when the tennon on the bowl was just a shade too big and I tried to make the jaws open a little more, resulting in one of the slides becoming disengaed, don't hammer it, just feel with your hands and push while rotating the handle.
Good luck
Jorge
Re: Stuck Chuck
Re: Stuck Chuck
Sheldon Grand
>I located the slot under the immovable jaw and cut
away the pin jamming the jaw using a one-eighth inch
endmill (in the drill press using a vise affixed firmly to
the drill press table). At that point the chuck became
unstuck and I un-assembled it completely; after
cleaning off accumulated gunk (mainly oily sawdust),
I'm ready to re-assemble it. Before doing so should I
coat the moving parts with (a) oil, (b) grease, (c) paste
wax, (d) something else, or (e) none of the above? Also
thoughts on whether to start the spiral at jaw one or at
jaw four will be appreciated....
Re: Stuck Chuck
Re: Stuck Chuck
>Start with 1 and go to 4. I can't remember whether they are clockwise or counter clockwise. (I am dysgraphic or dyslexic or something and trying to figure this out AND explain it to you would drive me completely insane. As opposed to my usual state of nearly insane.) When I did it I had another chuck to compare it to.
You need a dry lubricant that won't attract sawdust. I used graphite because I had it. There Are other dry lubes.
Re: Stuck Chuck
Re: Stuck Chuck
Bill Howatt
>Oneway says to soak their chucks in mineral spirits with 10% oil added if they become "sticky". So they think a very little, very light oil is OK. I use that on my Oneways and they don't seem to be giant dust magnets but like every mechanical gizmo you do need to monitor the situation and clean them when necessary.
Bill
Re: Stuck Chuck
Re:I occasionally give my chucks....
JamieDonaldson
>... a few shots of WD-40, then blow them out with the compressor. They will sling any lubricant you apply all over you, so use something that tastes good!
Re: Stuck Chuck
Re: Stuck Chuck
Don Evans
>I'm not going to get much support with this opinion but actually a chuck should not need ANY lubication in it. It works against you more than for you. Mostly attracting and hold gunk in the chuck which causes harder operation.
Lub isn't really needed unless you are superman and can turn the crank so fast you generate heat with opening and closing it. :D In such a case heat would expand the parts and cause more friction causing it to be harder to turn, maybe. :\
Anything that make the chuck easier to move can also help it loosen during use. Usually not a problem that way though.
On another subject regarding YOUR chuck. I interpreted your problem to be the jaw got stuck on top of the screw that is there to stop you from opening the jaws to wide?
You ground it off to get it unsuck? If so, you need to replace it as it is there for reasons of safety. You must have really been cranking on chuck handle to do that? Or was it just bad design? (screw too short in relation to slope in jaws ability to move up and down in the slide).
Don
Re: Stuck Chuck
NO Lubrication
Doc Green
>I agree with Don. I have Oneway chucks and have spent considerable time and energy keeping them so that they open and close freely, meaning that you can turn the key easily with only a thumb and index finger until it engages the wood.
For about a year I've not used any lubricant at all on the chucks and have not observed any harmful effects, like sloppy jaws or wear. Just recently, I took one of the Talons completely apart (for a photo), and the scroll looked good as new. No observable wear.
I've found that the best way to keep them free and easy to adjust is simply to blow the dust out of them frequently, like every time I have the air hose in my hand, I give the chuck a squirt.
On the other hand, when I've had them bind up so that considerable force was required to turn the key, an accumulation of dust turned out to be the problem. And sometimes it takes considerable fiddlin' to get the dust out, even with a dry chuck and compressed air.
So, based on my experience and observations, I think it is best to use no lubrication at all. ~Doc
Re: Stuck Chuck
Re: NO Lubrication
>I like to use a bit of dry lubricant - I use a spray can with graphite in a quick-drying liquid. No chance of it being sticky and attracting dust.
If the chuck binds, it may well be from over-tightening. I bought some used Supernova chucks from a guy once who either ate his Wheaties every day or used a cheater bar. The body of the chuck was actually warped slightly from the stress. I took some effort to disassemble and some time to dress the moving parts with diamond hones and files to make it work properly.
