>I am looking for some guidance in attempting my first bowl turning. I guess I could get a book or look on line, but thought maybe someone could point me at a site. I imagine that I need a thick piece of wood to start with and not sure how to select material. Do I go to a lumber yard and bye a small piece of 8/4 or 12/4 stock (seems costly). Or do I make a glue-up? I appreciate any info available, I have signed up for a class to try using a lathe before I buy one. However the class is general woodworking, and instruction in turning is not available , BUT, they got a nice lathe to use.
You've come to an excellent resource for your questions - Visit Woodcentral often and you will learn a lot - even just from reading the posts...
I suggest that you get some 8/4 hardwood stock (poplar is fine) if you want to practice your turning technique; get a 6" wide 8/4 piece two or three feet long and you can prepare a set of 2" thick x 6" diameter blanks to use for your practice. Cut them round on the bandsaw, and you're set for several turning cycles. The blanks can be attached to a faceplate by using a glue-block of 3/4" material that is screwed to the faceplate. With some careful turning, the glue block can be used over and over.
You can also find fairly inexpensive bowl blanks (pre-rounded) of domestic wood species on eBay - sometimes you can get some real bargains. (I'd advise staying away from the more expensive blanks until you feel confident in your technique.)
You don't include your location in the post, but I also would advise you to seek-out a local woodturning club (or a woodworking club with some experienced turners in it) to get some personal instruction. Nothing beats working with an experienced turner to get input on how (and how not) to do specific cuts, the proper sequence for shaping and hollowing, directions of cuts, which tools to use when, how to sand and finish, etc. You can learn a lot of the basics from videos, but having someone watch you turn, stop and comment when needed, or demonstrate good technique is really valuable. If you need to work from a video, I would recommend Bil Grumbine's first video which is both instructive and entertaining.
The link below is the AAW's Local Chapter page - you can search for a woodturning club near you and inquire about when their meetings are, and if they have a teaching/mentoring program. I would encourage you to go this route as the fastest and most enjoyable way to get the advice and experience you are seeking. I've never heard of a woodturning club who turns away an interested potential woodturner - they are, in general, excellent people with hearts of gold that are interested in sharing their knowledge and skill with others of similar interest.
Please return here often, and don't be afraid of asking questions - we've all been there.
>All of your questions can be answered in one video. Bill Grumbines video on bowl turning. There are actually a lot more questions that you will want to ask that are covered in that video. I know video's aren't cheap but it will be the best money you can spend. It will save a lot of heartache and make turning a lot more fun.
>Turn a bowl with someone who knows how. There is nothing which compares to a hands on learning the process. How do you find someone to turn a bowl with? Take a class, join a woodturning club, go to a craft show and talk to the guy selling bowls. Videos, books, the internet are good for reinforcing what you know. They are also good for helping you to use the techniques you know in different ways.
What is the value of a completed bowl? A 6"x2" bowl has a value of $20 to $100+. A 6x2 bowl is made from 1/2 bf of wood. The cost for 1/2 bf of wood at a lumber yard is how much? Between $1.50 and $20 depending on species, grade and uniqueness.
>Go to the AAW link Rob provided and find the chapter nearest you. Contact the person listed for that chapter and get to the meetings. Ask if they have a mentor program which they most likely will have and get with one of more of the mentors. Then get Bill Grumbines video...it's one of the best.
Then let us know how it's going for you cuz we like to help. Good Luck and welcome.
>Welcome to WoodCentral and to wood turning. Hope turning gives you as much pleasure as it has many of us here. This is a wonderful forum with lots of knowledgeable and helpful people.
You have gotten good advice. Find a mentor. Could just be somebody that is already turning, but it will be very helpful. You will find there is much to know and many ways to do most of the things we do. For instance, you can turn a bowl on a face plate or you can use a chuck. Some people swear the faceplate is better and cheaper, others swear a chuck is easier and more versatile. You get to decide. You can turn a lot of bowls before you decide to buy a chuck.
You will find there are more things to do in the world of turning than you have thought of. It is amazing how many applications there are.
You mentioned gluing up a blank. I believe most of us think gluing up a stack of pieces and turning a bowl that comes out as a stack of rings is a little tacky and not nearly as desirable as making it out of a solid piece of wood. OTOH, there are "ring tools" that let you take a board and cut it into a series of rings, stack them up and glue them and make a bowl. And there is the world of Segmented turning. Taking somewhere between dozens and literally thousands of pieces and gluing them together into rings and then gluing the rings into stack and turning them into pieces that have fantastic designs. They can range from an efficient use of small pieces of wood to truly amazing works of art.
You have come to WoodCentral at a slightly awkward moment in its history. the board is having some growing pains. Ellis, the Host has upgraded the software and if you read some of the other posts you will see that the process is having some birthing pains and being rolled out incrementally. One of the things that we don't have at the moment is the Search Function. It should be available in less than a week and when it is you will be able to search back for messages that contain information you are interested in. I am not sure if the Archives are up and running, but there is a lifetime of useful information there. So, Bear with it for a few days and watch it come back to life.
Also, Another facet of turning is acquiring wood. Many of us like to get free wood. Watch for trees being cut down. Tree trimmers in the city or where ever you see them. Many of them will give you pieces. If you want a bunch or want them to cut them to your specs, you may have to tip them a bit. Make friends with them and some of them will bring you more wood than you can use. Not quite free perhaps but nearly. OTOH you are learning that the lathe is the cheap part of this hobby. Next you will be wanting a chainsaw and a band saw. Enjoy
A glue-up is a wonderful way to experiment with turning and even to make fantastic and creative finished turnings. (Rude Osolnik even turned plywood) The very first bowl I made was from several pieces of 4/4 oak board glued together, mostly because I wanted to make a bowl and didn't know where to get thick enough wood! It came out fine, especially for my first try. (It was even treasured by a sister!)
Gluing up 4/4 is often far cheaper than buying quality 8/4 or better, 12/4 stock and a bunch easier to find.
Many bowls (and actually most larger things) are turned from green wood. Turning wet wood requires a few special techniques but is great fun and is a lot easier to work than very dry wood. Depending on where you live, great wood for bowl-turning may be free if you have a chain saw or know someone who does. Look for people cutting down a yard tree - they will often welcome someone to haul some away. People who cut and sell firewood will probably split a round in two for you for little or nothing. Tree services often dump logs where pieces can be salvaged. Or find some local small sawmills. (forget this if you live in the middle of the desert!) I have a small sawmill behind my barn and ALWAYS have far more wood than I can even imagine using. It's easy to whack off a useful chunk from the tree. Some sawmills will even save burls and give them to turners. Hey, I made the bowl in the picture below from a piece of white oak I split open while splitting firewood
Bowl from firewood.
Another place to get wood when starting: other woodturners! Turners in your area may love help you get started. Most people have more wood than they need (and they know it!) If you happen to live in East TN, come by and I'll load up your trunk. A good place to meet woodturners is at a club, if there is one in your area. Our club in Knoxville raffles off donated chunks of wood every meeting - lots of people bring useful wood. For example, last meeting I took two nice bowl-sized blanks of walnut to the meeting that had just come off the sawmill the hour before. I'll take some big blocks of cherry next month.
The worst place to get wood, especially for practice, is from an exotic wood dealer. Save that for later. I've got some big chunks of very valuable wood on my shelves that I was afraid to risk wasting when I started turning!
>When I first starting turning bowls, many years ago, I had a problem of where to get wood large enough to turn a bowl. I read an article in one of the woodworking magazines, this was before there were any woodturning magazines, on segmented turning. I gave it a try using some 2x6 inch boards I had on hand, I think they may have been pine. I the 2x6 into a number of slices and then used my chop saw to cut those into segments.
>In my last post, my link to the article on making bowls from flat boards was deleted. I have gone through the registration process and now it may work.
>Lumber yard wood might be the worst place to go for your first bowl. Kiln dried wood is really tough to turn. Go to a firewood pile and get a good piece of wet wood. Maple would be a great choice, cherry even better. I'd suggest that you find a local AAW chapter and see if they have a montoring program. You can't beat hands on training. That guy can teach you how to sharpen a bowl gouge, and even better, show you how to use it. This will so much better than book learning. Youtube is probably a good place to get some background, but there is a lot of bad info on there too. Good Luck!
I'm climbing the risers and joining the chorus. The best way to learn to turn bowls is in person, with a mentor or teacher showing you how. If there's a turning club anywhere near you, seek them out, go to a few meetings, and you will certainly find someone who can help you learn. Someone has already provided the AAW link, where you can find the local chapters. Talk to a few people and ask who would be a good person to help you learn the ropes.
Turners are generally very willing to share their time and experience, and will likely invite you over to turn a bowl at their shop, or offer to help you with your equipment.
Second best would be a good video presentation. I like videos a lot, but they tend to show you what to do, while an experienced mentor can also help with what you're doing wrong.
Books are a good resource, but this is fairly complex stuff, and they are better at reinforcing what you have learned. I can look at photos in a turning book now, and see all sorts of detail that I missed earlier, when I was starting out. After you make a few dozen bowls, you'll be able to notice or take in more information based on your experience.
YouTube has all manner of cool stuff, including some good turning segments, but there are postings that show everything being done wrong -- be careful.
